Need or Want ?
COOL
Feb 16, 2009
118
Islander 30 mkII Downtown Long Beach
What does the size of the boat have to do with hauling all that ground tackle off the bottom with my back?
The larger the boat, the heavier the ground tackle.
But if you have a bad back, I see where you are coming from.
I tend to see the work involved with sailing and cruising as part
of a healthy exercise regimen.
Bob, another little trick...
My problems have come when it's blowing 25-30kts with waves. It's a bear pulling the 10,000 lb boat over the anchor as I try directing the admiral in the right direction! .
We had that problem, too. My investigations showed I was doing it all wrong by trying it that way. You may never really know exactly where it is, so figure out a way to simply motor past the anchor (avoiding having the prop catch the rode) and drive PAST the anchor. As the wind is blowing you back, heave in the rode as fast as you can. Sooner or later you'll have such short scope the anchor will pull itself out, and you can retrieve it on board.
I hear ya, I know how hard it is trying to do that.
