I'm a little confused here. Are you saying you have a new engine in hull #57? My hull no. is #231, built in 2003. If so, perhaps you have a new style Sherwood pump. I too, used to remove the three bolts on the pump body, and remove the front of the pump, but that part of the pump was the body itself, and the hoses had to be removed first. Mine also did not have a circlip holding the impeller on.Purchased hull# 57 Catalina 310 2012 Universal M25XPBC, decided to change the impeller in 2014 after 600 Hrs. Took the pump off the engine and replaced impeller the pump looks like the in the manual and is stamped Sherwood didn't see any model#. After replacing the pump I looked to see why the impeller could not be replaced with the pump on the engine. With the pump on the engine I only need to take the 3 bolts which hold on the front plate from behind the pump take off the front plate pry out the impeller and replace. I did notice there was not a wearplate or circlip in the pump. Am I missing something maybe this not the original pump?
Thanks for any info
Have really enjoyed this boat and am learning the engine
If you have a picture handy, that would help a lot.
