Thanks MSter... Took the pump to the rebuilder and ran into this guy in NY who is very knowledgeable with these older Volvo engines. He has obsolete parts that he had made 3rd party which is where i got my two high press tubes and head gaskets. I called him up and told him of my plight and he said he had a "few" minutes to talk. I told him I replaced liners/pistons/rings/valve work etc and it has 400 lbs of compression. It started and run up in neutral but go into forward, and throttle it up and notthing happens. We discussed linkage between governor and injector pump whch seems good.Once we get it up and running, we can look through a borescope and see what's happening when it goes into gear. The gov shoud come up. This used to work before i ripped the plump out. So this guy in NY took me through the bleeding procedure and when he got to the inectors iI stated that I cannot bleed injector pumps because the heat exchanger sits righ ton top of the manilfold and injectors. Can't get in with a wrench to th injector nut. I just said i cranked until air makes it through the system....Well, most air lines go back to the fuel tank. Volvo returns fue bback to the seconedary fiter which heads back into the injector pump. I was told fuel woujld never get over the air locks that develop in the lines. So, this weekend, such that I have, I'm going to remount the pump and time it right. now that injectors are out I can turn the engine over by hand and get fuel up to the injector conccector Or I can try to make a flat bent over wrench that might slip in there. I might just take the belt off so no fwc running and no raw water runnig leave the HX off and actually try and bleed and start the engine then immediatly stop it as it has 0 cooling. Maybe there's a special tool somewhere. Not many of these were FWC though
