Low Power/RPM Universal M25XP
Jan 27, 2008
3,092
ODay 35 Beaufort, NC
What did the fuel look like when you tested your pump? It should be perfectly clear with a yellow tint. Any cloudiness or crud that looks like jelly floating around suggests contaminated fuel. Water in the tank might also be a suspect. Fuel hoses should be changed every ten years as someone noted previously they can deteriorate. I had one crack and start leaking yet the motor still ran fine. Your symptoms sound like fuel starvation.
Jun 2, 2014
606
Catalina 30 mkII - 1987 Alamitos Bay Marina, LB, CA
It looked very clear to me. But if you've ever got fuel from a marina here, your fuel isn't yellow, it's red.
Mine is a very light red because I often take a jerry can and get diesel from a local gas station instead. I seldom pay the $5/gallon at the marina for gas that hasn't had road tax paid for. It's about $3.50 at the gas station, and that's with the taxes.
