Lithium Batteries
Jan 7, 2011
5,732
Oday 322 East Chicago, IN
I got out to check the batteries today, and I captured the charger info as well…and I feel better today seeing the battery voltages and SOC’ s.
first, charger reports…I turned off power to go to the fuel dock and pump out, and then turned the power off again to check something else…so ypu see a few short charges most recently. But you see a few longer duration charge cycles as well.
here are the charger settings for Li-ion…
and here are the battery statuses: Both batteries had exact same voltage, but SOC was off by 1%.
neither battery “disconnected” the Charge MOSFET.
I can probably live with this for my limited power needs.
Greg
Likes: Johann
That 1% difference may be due to cell balancing. The second battery was still balancing the cells.
Johann
Jun 3, 2004
532
Leopard 39 Pensacola
Nice. It’s possible one battery had a greater cell imbalance initially and needed a couple of charge cycles to get the cells closer. Maybe that was the cause of a higher level of protection preventing it from discharging before.
