How about the NTSB report ? https://www.boatinternational.com/yachts/news/visionf-82-yacht-fire-miami-flagship-battery-explosionFirst off, it should be noted that with LFP (LiFePo4) batteriers, they are safer than flooded lead acid batteries. FLA batteries can and do explode due to the release of hydrogen gas. [Remeber the Hindenburg?] Maine Sail has offered a cash reward to anyone who can provide evidence of a fire or expolson of an LFP battery and to the best of my knowelge, he has not yet needed to shell out any cash. They can provide enough current that other components will over heat and they then cause a fire but that is true of any large battery bank.
An abandoned ship full of EVs is burning in the Pacific
The crew of the Morning Midas had to abandon ship in lifeboats off the coast of Alaska.
Deadly Yacht Fire Believed To Be Caused by Lithium-Ion Batteries
A deadly yacht fire aboard a 70-foot Viking is believed to be caused by lithium-ion batteries.
Flooded lead acid batteries can explode (I've seen the aftermath), but they don't burn internally. The vented hydrogen though, can ignite if ignition protected equipment is not used and the batteries are not properly vented. Yes, there will be acid everywhere... The question is not whether Lithium (lifepo4) is safe, not safe or safer than Flooded/AGM, just that they have different installation considerations, which are reflected in published marine electrical standards and in manufacturer's installation instructions.
Under the right conditions, scientific research shows that LifePo4 can produce combustible gases. https://www.sciencedirect.com/science/article/abs/pii/S0957582024013995
"In this study, thermal runaway behaviors of two real-world LFP battery packs with different venting areas and void volumes were compared. Fire and explosion occurred in battery pack I, which had a small venting area and void volume. But such dangers did not appear in battery pack II, which came with a large venting area and void volume. To explain these phenomena, a new experimental method on a single LFP battery cell was proposed to analyze the venting behavior from the perspectives of venting."
Basically, properly built with good cells and a proper design, they are sufficiently safe. Nothing is 100% safe. How can you protect yourself? Buy reputable manufacturer packs!
The flammability of vented gases does not necessarily make them unsafe, given the right safeguards. Do we carry anything else very flammable on boats? Wood and fiberglass/resin burns well. We carry LPG, gasoline, diesel onboard safely everyday, so long as those systems are properly installed and maintained (who changes their LPG hoses every 20 years ???)
How long before admins lock down this thread ? ?? LOL
