kenyon 550 kerosene stove and oven
27
Hunter 1983 Cherubini 37 Cutter Solomons, Md
Hi all,
I have a 1983 37c with a kenyon kerosene stove and oven. I need some help in getting it operating again - it has an external tank - is there an easy way to tell how much kerosene is in it - suspect I may have to use a "dipstick" of some sort. I tried to pump it to get some pressure in the external tank but the pump did not seem to work - is it essential to have kerosene in the tank to pump in some pressure? Any place to get a replacement pump - it threads on a fitting that looks identical to a bike tube valve - got an old manual from kenyon today but they did not have anything on their external tank.
Would appreciate any help.
Thanks,
Jim
Hi,
Congrats on perservering with your kerosene stove. I have same boat, same year and same stove. Personally I love having a kerosene stove and cabin heater, but most here on the forum would not agree with me. The peace of mind of not having any explosive fuels on board is enough for me.
You do need to have some level of kerosene in the tank or it will take forever to pressurize it. Imagine pumping up a car tire with that pump versus pumping up a bicycle tire...
The only way I have ever found to get the leve of the tank is to use a dipstick (piece of 1/4" wood dowel in my case). remember that the dipstick will go in at an angle (on my tank anyway) so there is less kerosene than is indicated. If the tank is nearly empty, you might consider removing it and giving it a good cleaning. Kerosene and diesel tanks get pretty grungy over time.
The tank should be pumped up to between 10 & 15 PSI (need a working pressure gauge). The whole trick to these stoves is to religiously preheat them. Fill the the cup below the burner with alcohol, methanol, etc. A small used dishsoap bottle or similar works well as a dispenser. Light the alcohol and wait for it to burn out completely. Try to keep drafts away, as this will affect the preheating. As soon as the alcohol flame is out, turn the burner knob all the way to the left (anticlockwise). This will bring the "pricker" up into the burner nozzle orifice and ensure it is not blocked with soot, etc. Then immediately turn the knob 1/2 way to the right (clockwise) while applying your lighter or match to the burner. It should light right away and burn with a hot blue flame. If the flame is yellow and sooty, the burner was not preheated enough and you have to shutdown, wait for it to cool enough to safely refill the alcohol cup and start over. I have used a butane torch to preheat the burner underway, when it was too rough to keep alcohol burning in the cup. The trick with the torch is that it always takes longer than you think to get the burner up to temperature.
These stoves are getting harder to find parts for, since Force 10 in British Columbia and Patria in Portugal were bought out. I hear Holland Marine in Toronto has some parts and Taylors/Blake/Lavac in the UK can also supply. Good luck and happy cooking!
Jun 25, 2009
542
Hunter 33 Seabrooke, Houston
I found Jim Legere's comments on the kerosene stove very informative
I too have one such stove on my H33 (1982) which appears to be original; the stainless steel (?) container is inside the sliding panel, just above it
I have no idea which one I have, but ass I said, is the original
The oven has never been used, and all is there, so it appears
I would not have brought this up, but now that J.Burans started it, my question is: do I follow the same instructions as in his boat?
Is the metal container inside the cabinet removable?
I think I will take it off and give it a good clean
I am all for the originality of stuff ( still have 2 juke boxes from the 40's, and never owned a CD player: all vinyl records, so there you have it
SO; can I copy same instructions?
Thanks for the help that will be forthcoming (it never fails)
Jorge
Jun 1, 2010
27
can you use a regular bicycle pump for a "schraeder valve" to pressurize the external tank
Hi,
thanks for the very useful advice - love my boat - does yours have a taylor kerosene heater as well?? Ultimately need to get that going as well - question I have is for the kenyon external tank - the hand pump I have doesn't seem to be working well - the valve attachment on the tank appears to be like a achrader valve on a bicycle tube - most bicycle pumps today "clamp"on to these valves versus screwing on - since I have been unable to find a replacement pump from kenyon what do you think about trying a bicycle pump>? My tank does have the pressure gauge.
Thanks,
Jim
5,802
I sold my Kenyon recently. It sat in the garage for eight years. I could have gone and tested the bicycle pump theory. It should work well though. Any good floor pump will have a gauge as well. You can check that the tank gauge is working. You are correct, the pump head will clamp on, not screw on. That should not present a problem.
Bicycle pump - yes!
Jim, a bicycle pump or any other type of pump that will connect to a schraeder valve will work and you don't need much pressure - a pump that will make 20 PSI should do.
I have a Force 10 heater in my cabin, fed from a Tee on the same kerosene tank that supplies the stove. Nice to have on soggy, damp days like today in Halifax is. Boat, which was from the Cheasepeake area, came with one of those over the hatch marine AC units - sold that down there and put a heater in when I got her back to Canada. Great white north, eh?
Somewhere I have a good kerosene burner manual that came with the Force 10 heater. I will find it, scan it and put it on this site for all the kerosene fans.
BTW, never try to use kerosene in oil lamps in the cabin - you eyes will sting for weeks. Instead, buy the purest, clearest (most expensive) lamp oil - aka parrafin - that you can find. I have 3 oil lamps. My favourite is the Den Hann Jr. Trawler lamp from Holland. It has a circular wick and burns really bright. We ony ever use the electric lighting for convenience - like going to the heads or searching in the icebox. We also use a kerosene riding or anchor lamp. Outside, kerosene is no problem. I draw the line at kerosene powered running lights however. I dunno, kerosene seems like a traditional and seaman-like fuel to me.
Sep 10, 2009
194
Hunter cutter 37 1981 St-lambert
My kenyon stove still sits proudly where it belongs :). It works almost perfectly. I only have an issue with one of the burners. It's seems like there's some debris of some sort somere in the line close to the burner. When I light it, the flame start 'dancing' after a while, and it gets more and more violent till it the flame goes out. Since I didn't needed the two burners, I never really at this problem too much in detail (tought I remember changing the whole burner at some point), but I will need to figure this out before leaving in september. I would never put a propane stove on my boat, nor would I put a gasoline engine. Here some pictures of the stove and of the tank with gage and bicycle valve. I use a small pump made for basketballs...
Jim, do you use a Tilley wick to keep the alcool from spilling all over the place when underway or do you always use the butane torch ?
What a good idea! I never thought to use a wick, but I have used a piece of tissue paper soaked with alcohol in a pinch. Usually I just grab the torch if its really rough. I'll try the wick next time.
I uploaded the Force 10 burner manual to the Resources/Downloads part of the website, but I just noticed that another ABYC electrical document that I uploaded a couple of months ago is not accesible - still in the "moderation queue". Maybe Phil Herring or one of you can tell me the best way to upload PDF documents to the Hunter Owners site.
Likes: 1 person
Jun 3, 2004
890
Hunter 34 Toronto, Ontario Canada
tell me some more about the wick idea- do you leave the wick in the alcohol circle when you light the kerosene? We have not used the kerosene stove much as it frightens the daylight out of my wife and I am in more danger of her and her fire extinguisher running around behind me as I light it than the fire itself! I would like to find a way of preventing the high flames from the alcohol on the preheat - is it just practice in knowing the amount of alcohol necessary?
Sep 10, 2009
194
Humm, I can't give out much more info about the wick idea, I stole that idea on a forum a while ago when I was trying to find a new burner for my stove. I aven't tried it yet, but I will for sure.
May 31, 2007
784
Hunter 37 cutter Blind River
The bike pump with the clamp works just fine. I bought a big blue foot model from Can Tire and it requires fewer pumps. ( I kept it on the counter and didn't use my foot.
You guys are so lucky. Your Kenyon stoves are stainless. Mine was enameled.
I have replaced mine with non pressure alcohol because it is easier for charter guests to use but I sure do miss the extra heat and excitement of the kerosene. I am saving that stove! And the one on the 33 should work just the same.
Jun 1, 2010
27
Have one burner on the kenyon kerosene stove working great!
To all,
Thanks for the advice - a bike pump with a schraeder valve capability works great - pumps the pressure up in the external tank with 3 or 4 pumps. Using synthetic kerosene - no smoke- burns very clean. One burner working great - heated up with alcohol in pan below the burner. The other burner gets heated and almost kicks into a blue flame but it is blue green with yellow and then doesn't ever go all blue. Appears to be working but I am not getting quite hot enough - will try again heating with alcohol and then with a torch and see what happens.
Regards,
Jim
Jan 2, 2008
547
Hunter 33 (Cherubini design Forked River, Barnegat Bay, NJ
Jorge:
Unless someone did a radical change on your boat your stove should be alcohol. Starting procedure is the same except alcoholin the tank instead of Kerosene. Even burning 196 proof ethanol the smell got to me. I replaced mine and ended up with a sinlle camping stove that runs on propane cylinders. Simple.
Jun 1, 2010
27
it is a kerosene stove
Hi,
my stove isn't alcohol but pressurized kerosene.
Jim
Jan 2, 2008
547
Fascinating. The link that MATHURIN2 points us to specifically states that the 550 (2 burner) / 555 ( 3 burner ) are alcohol stoves.
May 31, 2007
784
The alcohol stoves have a single post which bolts to the stove top and through which the alcohol is fed. The kerosene one has a Y shaped post and the burner is much harder to take apart. I bought my boat (1982) with a kerosene stove but found the invoices etc. on board indicating the original owner had opted for kerosene and the dealer had swapped them out.
Jun 1, 2010
27
any ideas on how to get my second burner operating??
one burner works fine after the external tank is pressurized - I put alcohol in the cup beneath both burners and lit them - waited for the alcohol to burn out - turned on the burner when the alcohol fire went out one burner instantly turned blue - the other was under pressure with some blue at the base and yellow at the top - burned like this for about 3 minutes then the yellow flame grew larger and started to get sooty - tried it 3 times waiting for it to cool in between - never got it to "kick off" into a pure blue flame - burner seems to be working, no clog as kerosene is flowing into it - just doesn't seem to get hot enough - perhaps I should heat with alcohol and then with the gas torch for a bit then try it - perhaps a bit of carbon buildup is "holding it back" a bit?? Resisting taking the burner apart - have turned the nob all the way to the left to clean the jet - when it cools a very fine spray of kerosene comes out - so I don't think it is clogged.
Any help would be appreciated!
Dec 2, 1999
15,184
I would remove the burner and soak it in Carb cleaner. Then use a needle to clean out the tubes. Soak it in carb cleaner again and rinse it with alchol.
May 31, 2007
784
The problem could be a very small leak somewhere - probably the packing at the stem where the adjustment handle exits the burner. Usually poor packing shows up as a flame there but not always. I like Steve's carb cleaner idea but if you can repair it without taking the burner off the stove, BIG bonus.
