Invest 95L --> TD 13 --> TS Lee --> Hurricane Lee --> PTS Lee
JamesG161
Feb 14, 2014
8,105
Hunter 430 Waveland, MS
what actual level was that?
We normally look at 200mb level for major steering currents. aka Jet Stream.
If we want to look at Vorticity or Shear , we use 500mb
The Hurricane Hunters us a drop buoy with mandatory levels of 500, 700, 800mb and Sea Level.
Jim...
Interesting discussion in the latest Tropical Tidbits video
He always does a good job explaining the various factors that go into both steering the systems and driving forecast uncertainty.
On the good side it looks like the one behind Lee is headed toward fish storm territory. :clap:
7,732
Alden 50 Sarasota, Florida
Jim...
Jim
At what point, I.e., how far away from the U.S., do the hurricane hunters fly to transit a storm?
JamesG161
Feb 14, 2014
8,105
There are several departure points.
1) Antilles
2) Puerto Rico
3) Florida and North if needed.
4) Or near me from Kessler AFB
Jim...
JamesG161
Feb 14, 2014
8,105
That Hurricane Hunter flight above landed in San Juan , Puerto Rico.
Waiting on TS Lee to draw near.
Jim...
JamesG161
Feb 14, 2014
8,105
Where are the NOAA aircraft based & fly from?
Based in Florida at 2 different AFB's.
They are new aircraft with Doppler Radar in the Nose section and can drop different weather items into the storm.
Jim...
JamesG161
Feb 14, 2014
8,105
They and their ground crew are moving now to Puerto Rico.
Recon Flights are Named by the Aircraft flown
1) NOAA
2) AF [the original Hurricane Hunters]
All of them are Heroes !!! :clap:
Jim...
JamesG161
Feb 14, 2014
8,105
Using Windy.com and the forecast it shows, the above chart looks like this a few days from now.
Please note this is a weak forecast today.
But we show it for clarification of the 500mb or 500hPa winds, plus this intensity [wind speeds] shown is at that pressure level.
Jim and John.
PS: Note the Legend of Winds Speed, in knots, in the Lower Right of the above Picture.
May 23, 2016
217
O'Day 1984 23 Island Park, NY
Have to admit I'm a little confused... First you said 200mb level for steering winds, 500mB for vorticity and shear... but you labelled the plot from Windy as 500mb stearing winds? What am I missing?
Nothing really.
Windy shows levels above the surface in hPa = hectopascal, 200 hPa = 200 millibar.
The Jet Stream flows upper level at 150-250hPa (250pHa is flight level 340 - 34,000 ft above sea level) and is the primary driver of winds around the planet.
Moving closer to earth High and Low pressure cells are also influenced by the winds at 500hPa as they hit the “gut level” (not a scientific term but it is a good analogy ) of the storm.
The upper level winds can “Shear” off the tops and tilt the storm cells. They can change the make up of the storm bringing in different air moisture levels. All of which impact the way the storm develops or dies. It is a dynamic process In ever motion.
Then you have the High and Low cells interacting. High pressure cells spin clockwise, Low pressure cells spin counter clockwise… Ever play with spinning tops. Try it some time. Lots of fun.
Likes: JamesG161
Oct 1, 2007
1,865
It appears the juju isn't improving too much....if we still had the big boat I'd be talking to the yard about an insurance haul.......still a long way off but I always would take the conservative approach...sailing out of Point Judy
3,220
Beneteau 343 Slidell, LA
Jim...
Yes they are & their service has saved lots of lives over the years.
Hard to believe that the idiots in Washington wanted to defund this squadron & flights, approximately 10 years ago, because it cost too much!! Thankfully, intelligent minds prevailed.
This is a storm that is well defined. Has a solid core with vertical development. A broad wind field and a forming eye wall. :yikes:
Keep an eye on this one. If you have a plan set a minimum 5 day schedule to implement your plan once the storm direction is identified. Be finished with your plan a day or two early.
Likes: JamesG161
JamesG161
Feb 14, 2014
8,105
Hurricane Lee is a very serious Storm. We just reviewed the Hurricane Hunters Flight information.
This is tightly wound up.
That Dropsonde #3 indicates it is in the EYE WALL :yikes:
John thought it was a bad instrument, but no way... this is the #3 drop info.
Dammit Jim and Bone Head John
PS: Tropical Tidbits our sponsor.
