I'm installing a scoop strainer on my 1980 C27. On the inside I will install a flanged seacock. Room is tight and I have a limited range in terms of the seacock orientation. As far as the scoop strainer there is a second option. I can install a normal mushroom through hull fitting and then a strainer plate over the through hull mushroom fitting. This can be done instead of the normal scoop strainer that has the through hull built into it.
Has anyone done the second option I mention above?
