Inboard performance
Nov 3, 2010
564
Oday 39 Lake mills WI
Blow-by often refers to combustion gasses "blowing by" the piston rings into the crank case, which is a sign of engine wear, but totally unrelated to your type of coolant overpressurization "blow-by". The fact that your engine runs smoothly and performs fine other than the (hopefully resolved) overheating suggests that it still has life left in it and shouldn't need replacement.
The items on top of the cylinders with the rigid hoses are actually the injectors, not the glow plugs.
As for tightening the hose clamps - you should be able to get them reasonably tight before they fail, certainly tight enough to prevent leaking unless they're badly corroded. I usually tighten them as tight as I can before it looks like hose rubber is starting to "ooze" into the perforations. Maine Sail would point out that the perforated style clamp isn't really the greatest. Search the archives and I believe you'll find his recommended alternative.
David has the correct definition of blow by. I guess your mechanics description is reasonable but in your case the coolant blow by is not a Sign of a warn out engine.
You might want to install a coolant overflow tank so you do not suck more air into the system each time the engine cools down. But once you install the water heater correctly your burping days will be over.
Now what is this talk about ripping your cockpit out to do fiberglass work? That sounds scary .....
Mar 1, 2016
276
Oday 28 Tracy's Landing
I do have a coolant overflow tank already. Cockpit has delamination and moisture build-up so I have some re-coring planned there. Other spots have high moisture and one slight void on the bow to be treated but cockpit is the worst. At the same time I'll be installing an auto-pilot and multi-function nav system/chart plotter, possibly replacing the binnacle.
Nov 3, 2010
564
Will you be removing old soggy core from the bottom (inside) ? This way you do not have to re gelcoat the top (outside)
Mar 1, 2016
276
That sounds like a great idea if possible. I'm planning the shop at my marina to take that on. I'll tell then that is my preferred approach.
