- Oct 22, 2014
- 23,786
3000 rpm. Max power is reported by Westerbeke to be 3600rpm. At that rpm the engine produces 18hp.
80% would be a little over 2800rpm. Now if you’re only moving the boat in and out of the marina you may never get the chance to run at cruise speeds. Then you should take the boat out and do the occasional cruise speed run to keep the engine healthy. The alternative is the engine will never get up to temperature and there will be excessive carbon buildup in the cylinders. This will lead to a premature engine overhaul.
If you are getting hull vibration at 2000 rpm’s then several issues may be occurring.
- Engine mounts loose
- Prop shaft not aligned
- Strut loose
- prop fouled
