The awning really is very simple to make especially if you use a sheet. They come hemmed at one end and only need to be hemmed at the other end. I would add a 3" strip to the center for the center pvc pipe, or even fold over the center an sew a pocket for the center pipe (you will loose a little length but nothing significant).
If you can't sew at all hire a seamstress. One should do it for about $10.
The poles have 3/16" holes at the ends where the 1/8" tie-downs are attached. I would drill a hole on only one side of the pole and feed the tie-down through it and tie a stopper knot that will be inside the tube for a cleaner look. The tie-downs are about 4' long and are tied to the stanchions.
I used to secure the center of the poles to the boom but found last week that is not necessary, even in 10-15 kt winds. I will draw plans for the verbally challenged.
