In other words, up and over the life lines?Rare in a discussion about sailing a consensus is emerging.
Route inside the life lines, not through them.
I have one. It has more details on MKII's than MKIII's. Rather inacurrate and missing info IMO. The stanchion in the video has been rebedded and reinforced with a G10 backing plateAlmost all Catalina masthead rigged boats with only inboard tracks get the jib sheets routed inboard. Has been this way since the C22 and C30s started production in the early 1970s.
You should have a manual for your boat, you've been here long enough to be able to access one.
Good luck have fun rebedding your stanchion bases.
Yes, that was a very lazy sailing day. Wind gusts to maybe 10kts with the autopilot doing all the work. These stanchions are definitely stronger than the ones on my last boat. I destroyed one with a fender. I'm aware of the risksYour Catalina has inboard shrouds which facilitate tighter sheeting angles.
Pull your fenders on deck when sailing.
Don't hang fenders from lifelines, see it making your slack lifeline jump up and down. It's taking a load then releasing, using the stanchion as a lever. Tie fenders to the base of stanchions so they aren't stressing them wrong way over and over 24/7.
Yes. See the photos Dave and ThinWater posted.In other words, up and over the life lines?
The previous owner attempted to get the towing function working but he said it wasn't working as expected. I ended up using the shock cord he had attached for another purpose. Sail trim and rig tuning has been low priority due to lack of time. Is the fairlead/cam cleat car for towing?Are you having trouble with the Genoa car maintaining its position? I ask because you have the hardware for a towable Genoa car, but it is not rigged. Towable cars make it very easy to adjust the position of the sheet lead while its under load and it does not require leaving the cockpit.
Yes. The towable cars that just slide on the track work but not as efficiently as Harken's ball bearing cars. Shock cord works on the Harken cars, not as well on the sliders. But that doesn't really matter in practice. When the jib is trimmed going up wind the jib sheet will naturally push the car aft. The tow line works best when going from upwind to off the wind when the car needs to come forward.The previous owner attempted to get the towing function working but he said it wasn't working as expected. I ended up using the shock cord he had attached for another purpose. Sail trim and rig tuning has been low priority due to lack of time. Is the fairlead/cam cleat car for towing?
I believe it's a 150. It goes past the mast pretty far. Wouldn't inside the shroud lead to a short sheet life due to constant rubbing?You look to be flying a standard jib. I would run the sheet inside the shroud and inside the lifelines. It looks like the jib is a 100%so that it fits in the “J” measurement (in front of the mast.). You will be able to sheet it in more cleanly (a fair lead). If you change the foresail cars to be adjustable (like an adjustable traveler) you will be able to make trim adjustments on the fly.![]()
Among other things, like beating up the Genoa, over trimming when going to weather, and poor off wind sail trim.Wouldn't inside the shroud lead to a short sheet life due to constant rubbing?
