In other words, up and over the life lines?Rare in a discussion about sailing a consensus is emerging.
Route inside the life lines, not through them.
I have one. It has more details on MKII's than MKIII's. Rather inacurrate and missing info IMO. The stanchion in the video has been rebedded and reinforced with a G10 backing plateAlmost all Catalina masthead rigged boats with only inboard tracks get the jib sheets routed inboard. Has been this way since the C22 and C30s started production in the early 1970s.
You should have a manual for your boat, you've been here long enough to be able to access one.
Good luck have fun rebedding your stanchion bases.
Yes, that was a very lazy sailing day. Wind gusts to maybe 10kts with the autopilot doing all the work. These stanchions are definitely stronger than the ones on my last boat. I destroyed one with a fender. I'm aware of the risksYour Catalina has inboard shrouds which facilitate tighter sheeting angles.
Pull your fenders on deck when sailing.
Don't hang fenders from lifelines, see it making your slack lifeline jump up and down. It's taking a load then releasing, using the stanchion as a lever. Tie fenders to the base of stanchions so they aren't stressing them wrong way over and over 24/7.
Yes. See the photos Dave and ThinWater posted.In other words, up and over the life lines?
