Ideal routing of jib sheet
From all the pictures I see of Catalina 30 MKIII’s, there’s a lot of space between the shrouds and the lifelines. That’s where the clew of the sail should be - outboard of the shrouds and inboard of the lifelines. This is true of many masthead rigs with large headsails. Upwind the trim angle should be acceptable because the shrouds are far enough inboard. Downwind the sheet might touch the lifelines a bit but no significant interference.
Fractional rigs are a different arrangement and often have smaller headsails sheeted inside the shrouds. Usually the shrouds on those rigs are further outboard. By sheeting inboard of the shrouds the upwind trim angle can be a little closer. Usually these types of rigs are put on boats that can take advantage of the tighter sheeting angle - sheet a jib too tight with a 150 sail on a heavy displacement boat and you’ll lose more power than the designer intended.
4,752
Catalina 30 MKIII Chicago
I rerouted the sheet. The sail shape looks a lot better. I tested it on a very light wind day. Hopefully conditions will be a bit more favorable next time so I can give it a good test. The wear patch on the sail lines up better with the spreaders as well.
Ward H
Nov 7, 2011
3,843
@Project_Mayhem , a little late as usual, but as the all others have said, yes, route the jib sheets inside of the life lines.
We were out in plus 20 last week, same routing with the sheets. No issues.
  • Helpful
