Ice box shelf?
Dec 25, 2014
84
Catalina 27 Pasadena, Md
Hi all,
Last fall bought a 1986 Catalina 27 (in awesome condition) but in looking at the ice box, it looks like there is a ledge that might have had some sort of a shelf to hold food or drinks above maybe a large bag of ice, the shelf would be about 14 1/2 x 23 1/4 inches in size. Does anyone know of anything like this in their icebox and if so might recomend where to get one? I checked CatalinaDirect and found nothing like what I imagine might have been there.
Thanks, Bob
Aug 13, 2012
533
Catalina 270 Ottawa
I have a C270, so it might be a bit different, but in mine there are plexiglass "shelves" that reside on these ledges and can be moved back and forth (if you need access below them).
A simple solution would be to cut a couple of rectangles that would fit there together. They don't need to be transparent. You may want to cut a finger hole so that you can lift them.
good luck
Catalina 320 Dana Point
I use the plastic coated wire shelving for closets in the icebox, different widths available, cut to length and little plastic caps on the cut ends.
Jun 16, 2014
18
Catalina 25 Muskegon Michigan
I use those in my ice chest...put a block of ice in the bottom and then the wire shelf to put the food on...keeps the food up and out of the melt water but still cold
