Here is the inside of my south coast 22... I had already cut out the plywood galley on the starboard side. I was planning on replacing the knee for the starboard chain plate and the port side bulkhead, also where the chain plate mounts. An hour later it was all gone..... by my rough math,
3 sheets of plywood should put it back together, with a slight redesign, as I never intend to use it for more than storage. This is a trial run for practice fitting installing bulkheads and interior bits on a great project down the road. Please stay tuned for progress updates.
I am not sure what the fiberglass tube in the bottom of the hull is, perhaps for moving it at the factory? There were 2 dead critters in the flotation. That makes 4 total dead critters so far.... A grand total of 9 feed sacks full of rotten foam.
