We have a green wire (#8) with a yellow stripe connected to a keel bolt in our bilge. The wire and ring terminal are corroded. Before I strip back the insulation and reattach the wire with a new terminal I am seeking some clarity on the purpose of this wire. I’m not sure if it is just lightning protection or part of a bonding or grounding circuit. I know there are other similar wires throughout the boat, but this is the only one sitting in a wet location. Should I move it to another site? If so, where? I plan on tracing the entire circuit to make sure all other connections are solid. Ill fix any connections that seem suspect.
