Hunter 49 Grounding/Bonding Wire
Jun 9, 2026
2
hunter 49 san diego
We have a green wire (#8) with a yellow stripe connected to a keel bolt in our bilge. The wire and ring terminal are corroded. Before I strip back the insulation and reattach the wire with a new terminal I am seeking some clarity on the purpose of this wire. I’m not sure if it is just lightning protection or part of a bonding or grounding circuit. I know there are other similar wires throughout the boat, but this is the only one sitting in a wet location. Should I move it to another site? If so, where? I plan on tracing the entire circuit to make sure all other connections are solid. Ill fix any connections that seem suspect.
It probably serves as a bonding wire and plays a part in lightning protection/mitigation. My guess is it’s interconnected with similar wires on any other underwater metals like seacocks. I’d reattach it back to the keel bolt to make sure the keel is in the circuit as designed.
colemj
Jul 13, 2004
1,184
Trace the wire and see where it goes on the other end. That will tell you everything.
Mark
These West Marine Advisor articles used to be easier to find, but they're still there.
May 24, 2004
7,237
CC 30 South Florida
Lightning protection is a game of chance. A strong lightning bolt will hit where it may and cause catastrophic damage no matter what mitigating systems may be in place. All we can go is by statistics that the overall chances of getting hit by a strike are very low. That more strikes happen near land than in open waters. That the chances of dying in a strike upon a sailboat are nil. (the cone of protection provided by the height of the mast seems to be a real thing). Minor strikes or proximity strikes are mostly confined to fried electronics which can be replaced. In a Marina surrounded by many other sailboats reduced your chances of being hit. In the water is best to sail away from land or cozy up to a few other boats in an anchorage. If you have affordable lightning insurance available that would be the best way of mitigating loses. Some swear by bonding and others would not touch it.
colemj
Jul 13, 2004
1,184
The purpose of bonding for lightning is not to prevent a strike or damage to electronics/electrics, but rather to give the strike a direct path to ground instead of blowing holes through the boat.
I've personally witnessed 3 boats get struck and begin to immediately sink because of exit holes through the hull.
We took a direct strike, but had a 2/0 bonding wire from the mast direct to a high-edge surface electrode in the water. The lightning followed that bond instead of finding ground through the hull, or even entering the hull at all. It was obvious by the burned insulation and discoloring of the electrode.
The only people disagreeing with lightning bonding a boat are lay people with no expertise, but only opinions and anecdotes. Everyone else knowledgable in industry and academics agrees that bonding is the way to mitigate damage, as well as increase personnel safety. This is codified in laws and industry recommendations. You will not see any commercial ships or land towers or buildings that are not bonded.
The cone of protection afforded by the mast is protection against a direct air strike to a person within it. It does not prevent electric shock if touching something metal at the time, nor does it prevent being struck by lightning inside the cone looking for a path out. There are many cases of people experiencing electrocution by being near the mast or having hands on the wheel.
Ironically, the cone of protection only exists when the boat is bonded for lightning.
Mark
Jun 9, 2026
2
hunter 49 san diego
I had some time to dig into the green wire situation on my boat, and here is what I found. The chain plates and mast are wired to a keel boat just aft of the mast. Other undiscovered items are wired to a different keel bolt in the main bilge area. The tricky part is that the connection point to the keel bolts appears to be a stud threaded into the rectangular washer under the keel bolt nut. The stud above the washer has disintegrated and only the outline of the remaining stud material still threaded into the washer is visible. It looks like I’ll have to drill into the stud and use a screw extractor to remove it and then replace it as it was. As things stand now, the cables are not attached to the keel at all. That are just wired together. I am debating creating a new attachment by using a large ring terminal to go onto the actual keel bolt and snug it up with an additional nut. That will keep it out of any water that may collect in the bottom of the bilge.
Don't worry about replacing the existing deteriorated screws. Pull the metal plate and drill and tap for a new screw in a different corner. It will be much easier to drill the SS plate using a drill press than trying to do in place in the bilge. Be sure to properly torque the nut when you reassemble it.
May 24, 2004
7,237
CC 30 South Florida
Mark
I don't disagree with bonding, just with the over reliance and assertion that it will mitigate damages in the majority of cases. I agree that bonding will provide protection in cases of minor strikes which without it could have caused holes and spyder cracks in the hull. I dispute the statement that there have been many cases of persons that have been electrocuted whether near the mast or with hands on the wheel from a lightning strike. I have been hard pressed over the years to find more than a handful reports of death related to lightning strikes on sailboats. Luckily all the odds are in our favor. There is one thing that must be stressed, the bonding has to be checked periodically and maintained. Just because a boat was bonded 20 years ago it does not mean that is still good.
colemj
Jul 13, 2004
1,184
Electrocution does not result in only deaths.
Without bonding, there is no cone of protection.
Bonding is not controversial or questioned by anyone with any knowledge of the subject backed up by experimental and actuarial facts.
Overall statistics showing a low chance of getting struck are useless. The only statistics that matter are local ones. If you are in coastal Caribe Panama, you have a 50% chance of taking a lightning strike. If you are in San Diego CA, it is 0%. I doubt you feel your chances in South Florida are as low as if you were in San Francisco.
Mark
MFD
Jun 23, 2016
306
Hunter 41DS Pacific NW USA
I would not make any changes other than restoring/repairing any as-built systems.
There are many opinions out there about what to ground, how to lightning-proof.
Your insurance company, yourself, and your time will be happy just following as-built and not worrying about lightings strikes or EMPs?
not worrying about lightning strikes or EMPs?:yikes:
OK, now you have done it. I have been trying to forget about the EMP issue.
Now the stories from the book will be in my head all day.
One Second After
2009 novel by William R. Forstchen
Apr 11, 2010
998
Hunter 38 Whitehall MI
One Second After
One of my favorite reads.
