Lightning protection is a game of chance. A strong lightning bolt will hit where it may and cause catastrophic damage no matter what mitigating systems may be in place. All we can go is by statistics that the overall chances of getting hit by a strike are very low. That more strikes happen near land than in open waters. That the chances of dying in a strike upon a sailboat are nil. (the cone of protection provided by the height of the mast seems to be a real thing). Minor strikes or proximity strikes are mostly confined to fried electronics which can be replaced. In a Marina surrounded by many other sailboats reduced your chances of being hit. In the water is best to sail away from land or cozy up to a few other boats in an anchorage. If you have affordable lightning insurance available that would be the best way of mitigating loses. Some swear by bonding and others would not touch it.
The purpose of bonding for lightning is not to prevent a strike or damage to electronics/electrics, but rather to give the strike a direct path to ground instead of blowing holes through the boat.
I've personally witnessed 3 boats get struck and begin to immediately sink because of exit holes through the hull.
We took a direct strike, but had a 2/0 bonding wire from the mast direct to a high-edge surface electrode in the water. The lightning followed that bond instead of finding ground through the hull, or even entering the hull at all. It was obvious by the burned insulation and discoloring of the electrode.
The only people disagreeing with lightning bonding a boat are lay people with no expertise, but only opinions and anecdotes. Everyone else knowledgable in industry and academics agrees that bonding is the way to mitigate damage, as well as increase personnel safety. This is codified in laws and industry recommendations. You will not see any commercial ships or land towers or buildings that are not bonded.
The cone of protection afforded by the mast is protection against a direct air strike to a person within it. It does not prevent electric shock if touching something metal at the time, nor does it prevent being struck by lightning inside the cone looking for a path out. There are many cases of people experiencing electrocution by being near the mast or having hands on the wheel.
Ironically, the cone of protection only exists when the boat is bonded for lightning.
Mark
