Hunter 376 Halyard Sheaves
mgg
Dec 10, 2022
7
Hunter 376 Punta Gorda
Anyone know where to find the specifications for the main, jib and spinnaker sheaves on the mast?
Dec 25, 2000
5,932
Isomat made the mast for our boat. The manufacturer knows the answer to sheave specs. RigRite has been a good site to visit for our mast questions. You will need to know who made yours as well as size. Typically, the size is based on the mast footprint, width and depth. You may find your brand there.
mgg
Dec 10, 2022
7
Thanks! I can't locate any mfg information on the mast. I checked out the rig-rite site, but could not find anything that matches with my base dimensions (9.0" x 5.4"). I've submitted a question to the Marlow Hunter website as well. I've attached a couple pics of my mast base in case anyone recognizes the manufacturer.
15
Hunter 376 Midland
I looked through the manual, which can be found on this site. Here is the link: https://sbo.sailboatowners.com/downloads/Hunter_376_10424794.pdf
I could find info for the sheaves at the deck, but not for the mast head… the manual does mention ZSpar parts at the base. However, this alternate thread might put you on the right track to find the info you need though. In short, USSpar took over the ZSpar manufacturing location and sold ZSpar product under a different name. USSpar may have the info you need.
I’d be very interested in knowing the answer if/when you find one.
I'd suggest calling the SBO shop on Monday and asking the question. They were the supervisors of the Hunter Service Department. With the year and boat model they may be able to help.
May 9, 2020
161
Hunter Legend 37 Harrison Twp, MI
Agree... best to get someone more experienced! But that doesn't stop me making a guess!
Based on the dimensions provided, I'd guess the mast is a Z-spars Z701. According to Rigrite...
Alan K
Feb 22, 2004
54
Hunter 380 Norwalk, CT
I own a 2000 Hunter 380 with a B & R rig. This was the same hull as the 376 as I recall. The mast step shown in the photo is similar to my mast step which was made by Selden. FWIW.
mgg
Dec 10, 2022
7
Thanks for all the replies. Sounds like my best bet is to pull them all down and take measurements. I guess I'll rig a temporary block for the trips up and down. An SBO rep says he needs hole diameters and thickness. I was just hoping to have parts in hand before going up. Thanks again.
Oct 29, 2018
26
Hunter MH37 Mississauga
Your mast is definitely Z-Spars. Give their service department a call with your hull / serial number and they can look it up. I did same a couple years back they they had all the details of the spec on my rig.
Hunter used both Selden and US / Z-Spars for their later model boat.
Likes: DSqr
mgg
Dec 10, 2022
7
Thanks for the ID'ing the mast. I sent an inquiry to US Spars, but no response yet. I'll try their phone in a day or two.
