Hopefully there is a simple way to do this.
no. the cover is a separate piece held down with screws into the deck. I think Catalina changed this aspect of the chain plates in the mid 2000s. I have watched a video from a 36 that changed to the new style. I didn't know they changed any of the 310s.Is your cover plate on topside welded to the chain plate? Mine is welded, also like @rpwillia, so I assume the through bolts and the bulkhead bots all have to be loosen to remove and then rebed.
NDT?Have you done and NDT? Mine is also in visual good shape, but we are lifetime freshwater and a lot less use then you.
