Holding Power
May 20, 2016
3,015
Thanks @Gunni — I do have a Fortress 20’ 5/16 and 250’ 5/8 3-strand as a backup and 500’ of 1/2 poly as a stern to shore line. I just don’t understand why the P.O. had such short lengths of chain, especially with the Lewmar Ocean concept 2 sitting on the bow.
@Kings Gambit - the reason for not going with the cyclone anchor is Incase the windlass gives out. As it sits there is over 160lbs of galvanized steel in that pile and I would hate to hoist it up by hand.
Anyone want a 15kg Bruce with a bit of chain as a backup? I’ll make you a good deal
Mahalo
Now I know why I have been invited aboard Mahalo... Anchor Meat. :yikes: Your going to go out and test anchor equipment and then say... Go to the bow John and haul up the anchor while I drive the boat. :banghead:I should have been more wary.
Oh well now that the secret is out. We will just have to...:hijack: bring out the best pirate behavior we can muster.:badbad::laugh:
JamesG161
Feb 14, 2014
8,019
Hunter 430 Waveland, MS
Bruce anchor = Mud bottom
Jim...
Oct 25, 2011
576
Island Packet IP31 Lake St. Louis, Montreal
TE="ifmdalvey, post: 1434004, member: 94122"]My previous experience was with a CQR but the quick resets is a company quote, so i am not disparaging the Bruce but would never return to an old style anchor.[/QUOTE]
Just curious... but did your Bruce fail often? Or did it just seem like the Mantus was more dug-in when your retrieved it?
Here is the basis for my comments:
We always anchor with 6:1 scope or more, when I expect some wind. We always pay pout the chain while backing the boat and carefully set the anchor, finishing with a final test at 2000 rpm in reverse.
Most of the time the Bruce (knock-off) did what it is designed to do but occasionally it would let go when we least expected it. I especially remember one morning, waking up feeling something was wrong, , after having been at anchor for 1.5 days with the wind around 10 kts from the west for the duration. The Bruce had let go. There were a few incidents before this incident erased any confidence I had in the anchor
There are a few differences we notice with the Mantus.
  • It sets much more positively and solidly than the Bruce ever did.
  • So far, it has set the first time, every time. That may change but so far that's our experience.
  • It takes more effort to break it out that it did to break out the Bruce
  • Often, the shank and the top of the arch are dirty indicating that they were below the surface of the bottom.
I sleep better these days.
Friends of ours (a confirmed Bruce fan for many years) bought a Rocna at about the same time we bought our Mantus and they have nothing but positive feedback as well.
Cheers
Matt
Is that all chain at 6:1?
- Will (Dragonfly)
Jul 27, 2011
5,180
Bavaria 38E Alamitos Bay
We always anchor with 6:1 scope or more, when I expect some wind. We always pay pout the chain while backing the boat and carefully set the anchor, finishing with a final test at 2000 rpm in reverse. Most of the time the Bruce (knock-off) did what it is designed to do but occasionally it would let go when we least expected it. I especially remember one morning, waking up feeling something was wrong, , after having been at anchor for 1.5 days with the wind around 10 kts from the west for the duration. The Bruce had let go. There were a few incidents before this incident erased any confidence I had in the anchor.
Cheers
Matt
Sounds like you had a general claw type of anchor; not a genuine Bruce--is that right?
Jul 27, 2011
5,180
It was a Bruce knock-off, yes
Well, I would not disparage the "Bruce" if it was not a genuine Bruce. It may be confusing to folks. However, I have no reason to doubt that your new anchor is superior to the one you had.
Oct 25, 2011
576
Of course you;re right, which is why I pointed out, in my post, earlier that We had a knock-off. I do wonder how many anchors out there are genuine vs. copies. Not just Bruces, but Danforths, "CQRs etc.
May 20, 2016
3,015
The Bruce both @jssailem and I are retiring are real Bruce’s, and mine has come unset mud/weeds and failed to reset. Woke up and had 1’ of water under the keel, combo of dragging ~30’ and lower tide. It was firmly set after a bit of skipping, 2000 for 2 minutes.
Jul 27, 2011
5,180
Probably many. I have what might be called a "knock off" CQR. It's a plow type anchor with a swivel at the neck as you see on CQRs. Different name, however--Plowmaster by Suncor. I usually refer to it as a CQR-type anchor. It has wider palms than a genuine CQR and is made of stainless steel. When I walk the docks for fun as I often do, I see MANY genuine CQRs on the boats. Along with genuine Bruces, Deltas, and Danforths. I see few of the newer ones--Mantus, Rochna, Spade, etc.
@LeslieTroyer and I will be putting his Mantus to the test the beginning of March. We will be able to report back with our findings. That is of course if the anchor holds. If it does not hold, who knows... you may have to call the Navy out as we drift along near Japan.
Sound fair..:). That is about the same amount of time those girls from Hawaii got.:laugh: Oh and the boat has a Hawaiian name "Mahalo":dancing: Coincidence...:yikes: Maybe?:thumbup:
But it will be so confusing when you call the rescue boat. Will you be saying Thank you, thank you, thank you, or simply saying the boat's name three times per VHF protocol?
Life gets so complicated sometimes. Oh yeah, don't forget to get the pole dancing photos before you go. :cool:
May 20, 2016
3,015
Oh come on John - I would notice we were drifting way before we pass Tatoosh Light --- plus with EPRIB, PLB, AIS, DCS and XYZ to alert the Canadian Navy you will have plenty of time to pull the anchor pulled up an properly stowed;:poke:
Les is the boat captain so the pole dancing honors go to him.. Besides some one has to maintain some sort of couth and decorum.
3,015
Pole Dancing -- I'm not Polish - I'm Norwegian -- and every one know us block heads stand around at dances and pick fights.
