high water?
Sep 22, 2018
1,869
Hunter 216 Kingston
Not looking promising as the level is way above “average” (which the last few years would have affected) and supply is outpacing outflow!!
Likes: danstanford
If there is any good news, it is the snow pack in NY is very low. If the snowfall continues to be low, we're about 2 feet below average, there will be less run off in March and April.
Of course, things could change. On March 12-14, 1993 there was a record snow storm in NY that dumped some 60" of snow in a couple of days. That was about 6 inches of water that entered the canal system in April and caused a lot of flooding.
Likes: jon hansen
Sep 22, 2018
1,869
Hunter 216 Kingston
Latest data from IJC - Lake Ontario.
Traditional flow reduction to let ice form, followed by warm trend where the ice melted, then increase of flow, now likely another reduction pending as we might get another cold snap. Argh!
I was talking to the owner of my marina, he's been going to meetings with FEMA and other agencies about the water levels. There are some predictions the water will reach 250 ft. The top of Moses Saunders Dam is at 252.
A couple of weeks ago the IJC released a paper on the 2019 Flood:
This is an interesting video on the M-S and water levels on the Lake and River.
  • Helpful
1,869
Hunter 216 Kingston
The relatively warm weather appears to have allowed greater than “normal” outflows from Lake Ontario. Water levels are still higher than ever (2017 and 2019) but the trend line is headed in the right direction. Crossing my fingers and toes that at the very least it gets down below those two years going into spring.
The WSJ had an article
On Rising Great Lakes, Backyards Are Disappearing Overnight
this AM discussing the loss of home lake frontage to the storms of 2019/2020. The 4-7 inch higher water in the lakes makes the lake front property vulnerable to the erosion issues caused by storms on the lakes. They article states these highs occur after record lows in 2013.
The quote at the end of the article reminds me that change occurs and those not willing to consider history are destined to repeat it.
Phil Jonassen, a freelance house mover, last week walked several of the properties in Oceana County, Mich., where he has relocation jobs under way. At one, he had lifted a beige home high off the ground and back from the eroding shoreline, where a road had washed away and left a neighbor’s driveway dangling off a cliff.
On a different lot where he had begun to lift a house for relocation, he stood at the edge of another eroded cliff, pointing to a spot where his grandfather’s cottage used to stand before the land it was on washed away in a period of high water in the mid-1980s.
“The same thing is happening right here, right now,” he said. “Everybody on the lake shore, they’re in a bad spot.”
Likes: JamesG161
OUT FLOWS..
You got to dump the water sometime. It is a guess. Will the April Showers and bring May flowers, or will they stay away and then what....:huh:
There is no easy answer when you are trying to control Mother Nature and keep everybody happy. Our City Engineer reminds me often, that his job is a success if he can keep at least 50% of the city's residents happy. I guess that is at least as good as most TV Weather personalities.:biggrin:
Likes: Hunter216
DArcy
Feb 11, 2017
1,788
Islander Freeport 36 Ottawa
Without a crystal ball to predict weather for the next few months, I would think trying to keep the water level close to the median would be a good idea. This might be adjusted for snow depths in the run off area.
Catalina 34 Casco Bay
On a more serious note the high water levels in the Great Lakes basin is perhaps the least of our worries. My grandson will be about 35. Check out the interactive maps.
I wouldn't say global warming... the catch phrase is now climate change.. I any event the temperature of the globe is not the only sinner... Every time shore front is reclaimed it adds to the increase. Every time ( which is always) an underwater sea mount grows, the water rises....and every time a new volcanic island is born... the water rises. It is an undisputed law of physics...fluids are incompressible !
1,869
Hunter 216 Kingston
I think today’s announcement is about a several week delay in opening the seaway this spring which provides an opportunity to make it look good. There has been a LOT of bad press lately so LOTS of pressure to DO SOMETHING.
If you look at the charts above there are three days of max outflow and 0 change on Lake Ontario level. Takes a lot of outflow to make any significant change.
Sep 22, 2018
1,869
Hunter 216 Kingston
I was reading recently about a report of record high temps in Antarctica 65F same as LA that day and that led me to look into ice melt. In recent years the melt in Antarctica has been in the area of 250 gigatonnes per year. That’s 250 cubic kilometres (slightly bigger than the size of Boston 1km thick) of water added each year.
If all of the ice in Antarctica melted it would raise sea levels 57 meters.
Sep 22, 2018
1,869
Hunter 216 Kingston
Latest data from IJC. Greater outflow this year due I believe to be warmer weather and less ice dam risk, but still LO level is record high. Ottawa River spring outflow is starting so outflow from LO will be reduced accordingly.
JamesG161
Feb 14, 2014
8,078
Hunter 430 Waveland, MS
From NASA...
High temp was on the northern most Island that is part of Antarctica.
"The region in question is Eagle Island, one of several islands peppered along the Graham Land peninsula–an area situated closer to South America than any other part of the Antarctic continent, and separated from Antarctica’s mainland by the 1.77 km wide Aripleri Passage."
Winter time ahead for Antarctica as it has gained more ice each year for last 2.
Don't worry about rising tides this year.;)
Jim...
Likes: Hunter216
Sep 22, 2018
1,869
Hunter 216 Kingston
Not very worried about tides on Lake Ontario ;)
Interesting graph on sea ice extent as current isn’t that far off average for all the press coverage on “disappearing ice caps”.
I have difficulty getting my head around measuring things in Gigatonnes, cubics Kms etc. The scale of nature vs man made boggles my mind!
JamesG161
Feb 14, 2014
8,078
We have geo-fixed satellites over each pole and are monitored and discussed here.
National Snow and Ice Data Center |
The key is our Sun and its radiation activities.
The snow fall and melt is a concern per this thread.;)
But it is down hill flow as long as the ocean levels don't rise, too much.:)
Jim...
PS: Also Sun's gravitational effects, that do cycle every ≈11 years.
PSS: They are wondering why the ice is increasing at that link.:hook2:
