- Dec 30, 2009
- 680
I thought my engine compartment was small...REd
1. Because the cable stretches. It's like DEFAULT values in computer programs. They are there specifically FOR the ability to adjust them.1. I was reading up about these the last few days and was going to play with them. My thought, however, was why they should NEED adjusting in the first place. Is it wear or a build up of dirt?
2. ETA: and why would BOTH screws need adjustment simultaneously? Seems to point to a governor problem except rpms are steady under way. Also, doesn't the idle stop spring and screw effectively do the same thing as the idle screw on the throttle?
Yep, had a beauty VW engine go south because the exhaust valve on the #3 cylinder was 2 thou' too tight. Burned the valve, dropped bits into the cylinder. You can imagine the rest of the story.anchorclanker said:Just an FYI, if not for yourself, for others reading. Valve wear does not always work to increase clearance. Seat wear of stem stretch can work to close up clearances. They can become so tight the valves start leaking compression and will burn the valves. This is why its so important to check them in some regular time frame. Lack of valve or tappet noise isnt always a good indication. In fact the opposite is a bit better, if your hearing them clack you at least know they arent tight. Loose is just noisy and reduces power some. Tights a killer.
I was reading up about these the last few days and was going to play with them. My thought, however, was why they should NEED adjusting in the first place. Is it wear or a build up of dirt? and why would BOTH screws need adjustment simultaneously? Seems to point to a governor problem except rpms are steady under way.
Stu, that link is fantastic!Well, I hope we got ac fixed on his emoticon access! :theman:
Over on Sailnet, we had a discussion with a skipper about idle speed. Maine Sail wrote this:
Originally Posted by Capt. Gary Randall
idle RPM should be 550 to 600 apparently you posted this right before I posted to you...lol
No it should not. That is HALF what the idle RPM on an M-25 should be.
The entire Universal M-25 line up, including the M-25, M-25XP and M-25-XPB are all 1000-1200 RPM for idle speed, per Westerbeke specifications.
__________________
______
-Maine Sail / CS-36T
The Hurth transmission shop manual discusses this, as noted here:
http://c34.org/bbs/index.php/topic,7020.0.html
That's where your idle speed should be. My tach is calibrated and I run 1000 to 1200 in idle and have had no issues with my transmission in the 14 years we've owned thsi 226 year old boat.
Good luck, KISS.
A photosensor tach from harbor freight. I then used it to calibrate my dashboard tach which I recently replaced when it decided to go all haywire on me.What are you using for a tachometer?
Yes, definitely had the right gauge. I made sure to retest the clearance after tightening down the nuts, though sometimes I had to re-adjust when the screw turned with the nut.And your 100% sure on the valve clearance that you did it right with the correct feeler gauge?
I dock single handed almost all the time and I really do appreciate being able to motor in very, very slow. Of course stalling out when you are inches from the dock and finding yourself scrambling to decide whether to try to restart the engine or to try to fend off an impending collision with a piling can be very challenging!You still have throttle control to always run it faster, but the lower setting can allow better speed control for docking, etc..
