Help me trouble shoot my engine! Update pg 5
I have a universal m18 diesel in my 1987 Catalina. As the hour meter is shot, I don't know how many hours have been put on it in its lifetime. I have owned this boat for two years now and have completed redone almost every item on the boat except the engine itself (yet!)
The engine starts okay and there are no major smoke issues noticeable at the exhaust, though I seem to get a buildup of black gunk on the transom above the exhaust port.
I need to keep the idle speed set at over 1000rpm to keep it stalling while in gear at minimum throttle, especially while docking.
The maximum rpm in neutral is about 2800-2900 rpm. Should be 3200 according to the manual.
I'm getting a "gentle breeze" from the crankcase breather tube and have since routed the end of it from its location clipped next to the air intake so that now it is piped directly into it the intake itself. The cabin was also filling with fumes before I did this.
I also get some vibrations at lower rpms when not under load which may or not be motor mount related.
I don't know if the engine has ever been overhauled before.
I've never done any "major" engine work before, but I wouldn't mind learning how to do it! (I have Nigel Calder's book next to me now). My biggest enemy here is physical access to the engine. It's almost all from the front and working from the side is possible too, but tight. I'm pretty confident the engine will get me through the season, but the perfectionist in me wants it to run at its best!
I'm thinking I should run a compression test at this point.
What do you guys think?
