Help ID sail maker please.
700
I've drawn a blank trying to ID the maker of my mylar genoa.
Anyone know who this is/was?
I did an image search and could not find it either. BTW That sail looks like dacron not mylar. Mylar is that crinkly stuff that baloons are made out of.
Mar 30, 2013
700
Well, I don't feel quite so dumb, at least one other person can't find it either :D
The sail definitely isn't dacron, that pic doesn't show construction real well and I might be using the wrong terminology. The sail is made of a net-like material sandwiched between 2 transparent-ish layers of sticky on the inside crinkely material.
Here is a better pic of the construction.
I wish all of it looked like that, the sail is really startingto show it's age and starting to delaminate, if you look at it too hard while tacking it will snag on your gaze.
http://s23.photobucket.com/user/FLHRI-OK/media/sail.jpg.html
Strange.... I've never seen a sail like that... kind of looks like a poly tarp. I'm guessing you could find a used sail that fits your boat on Bacon Sails or ebay etc. ???
Nov 8, 2010
11,386
Its a laminated sail cloth; two layers of Mylar (PET) film sandwiching a mesh of dacron threads. More of a racing sail... its light, and originally held its shape well.
Lofts don't use that material anymore:
1) Dacron is too stretchy to use in thread form. Does OK woven into cloth however.. Strings are now made from carbon, kevlar, spectra, or pentex.
2) Now the weave will not be square, but designed to be much stronger in one direction. The cloth will then be aligned at design-time to align with the loads on the sail. This is the so-called 'load-path' sail making process.
Older sails like that deformed rather quickly, loosing their shape in a season or so.
The current version of that cloth looks like this... Pentex threads aligned for loads West-east. Not as strong North-south but it will be sewn in strips that match that requirement on the sail.
Mar 30, 2013
700
It was probably a good sail when it was new but even the PO of my boat doesn't know when that was.
I should be done with my Sailrite luff conversion on what I believe to be the OE jib in time to try it Friday evening.
I just can't decide what to do with the old genoa, tossing it isn't really an option.
And, I'm still curious about who made it. :D
Tricia
Jun 4, 2004
87
Freedom 30 Victoria, BC
that logo looks like a long-gone sailmaker in Vancouver, BC
Macken Sails. Would that be possible?
Nov 8, 2010
11,386
For sure it was a good sail. If you want to repair that area where it hit the spreaders, put some sticky-back on it. Its what a sailmaker would do. We use it on our racing sails from day#1 in the area where the spreader might it it as a wear patch. You can get it from sailrite.
http://www.sailrite.com/Insignia-Adhesive-Backed-UV-Dacron-18
Feb 20, 2011
8,062
Tricia's got it, I think.
Address:
Macken Sails Ltd.
Paul Killeen
14 West 5th Avenue
CAN-BC V5Y 1H5 Vancouver
Contact:
Fon: +1-604873-9095
700
Macken Sails looks like the culprit. Did some searching on the name and found some old post talking about a similar sail.
