Hey All,
I'm doing my haul out first weekend of May in a DIY yard in SoCal. Besides painting, which I don't really need any help with, I plan on swapping out the cutlass bearing and the PSS shaft seal. The PSS seal is due, and since I've got to release the shaft to do it, I figure I might as well do the cutlass too, so they are both on the same maintenance schedule.
I am assuming I'll be able to get the transmission coupler off using either the socket method or buying the $50 tool on CD. Either way, I have options there.
For the cutlass bearing though, if I don't pull the shaft all the way out, I'll need one of those big expensive bearing tools I've seen all over the interwebs for $400.
So... two questions:
1 - If I'm already disconnecting the shaft at the engine for the PSS seal change, AND I'm already taking the prop off to install a new cutlass bearing, is there any reason I shouldn't just plan on sliding the shaft all the way out? Will it be easier to deal with the cutlass bearing with the shaft out? (like using a hack saw to cut it out) or would it be easier to leave the shaft in and get my hands on one of those fancy bearing pullers?
2 - IF it's just easier to get the cutlass bearing out by leaving the shaft in place, is there somewhere I can rent or borrow one of those tools locally?
