In the upper right of the screen, you should see your SBO login name. Click on that, then on account details, and you should be able to update your profile.I need to figure out how to update my profile. My boat is a Catalina 310.
Got it. Done! Thank you!In the upper right of the screen, you should see your SBO login name. Click on that, then on account details, and you should be able to update your profile.
Did you watch the video that Maine Sail made that is linked to in post #15? If it is stamped /edge crimped metal and not 100% welded construction it will leak which can be deadly. If you have a short piece of the flex pipe left over, I would unwind it to see if it is double wound. With this type of pipe, the middle of one wrap overlaps the middle of the previous one so that there are always two layers of stainless steel. Just because a mfr says marine does not mean it is safe for marine use.I need to figure out how to update my profile. My boat is a Catalina 310.
Autoterm claims in the manual that the exhaust line shipped with their kit is suitable for marine installs including their silencer. I will be carefully monitoring CO in the installation compartment with my low-level CO meter (measures down to 10ppm).
I do plan to do the condensation drain next. I've read varying/conflicting feedback if they're needed in the moderate ~50 degree F environments I'm running in. It will add a handy 90 degree bend which will allow me to get more "hump" in my exhaust for back-flood presentation.
Thanks! I will do the test with the flex pipe.Did you watch the video that Maine Sail made that is linked to in post #15? If it is stamped /edge crimped metal and not 100% welded construction it will leak which can be deadly. If you have a short piece of the flex pipe left over, I would unwind it to see if it is double wound. With this type of pipe, the middle of one wrap overlaps the middle of the previous one so that there are always two layers of stainless steel. Just because a mfr says marine does not mean it is safe for marine use.
The automotive flex pipe is attached edge to edge, so it is one layer thick. The marine flex pipe is attached edge to center so that it has 100% overlap for two layers full length.Thanks! I will do the test with the flex pipe.
This is the same setup I have except that I got the welded muffler from ebay for well less than Sure Marine charges. Their boat tax is pretty high.The exhaust silencer for our heating system is all welded and insulated with a fiberglass sock filled with insulation. These came from Sure Marine.
That is a nice looking exhaust and about what Sure marine charges for just the muffler.Now that I'm back to thinking about this, I took apart that Espar insulated assembly to see what things look line inside:
Seems like 24mm marine exhaust hose, a nice looking but very long (maybe 18" silencer), all wrapped in a sock and then the thin outside tube. It's not exactly "one piece," there is clearly some sealant where the exhaust hose enters and leaves the silencer, but it does seem well built and well sealed.
I'm not sure I'll get this to fit into my compartment, but going to try.
