I ran into a potential gotcha in my 34 on Sunday.
I cut away some of the the quarter berth bulkhead to get access to the batteries and fuel tank. While in the past I've noticed a notch cut in the plywood as it meets the "deck" and saw a hose there, I never gave it much thought.
The hose in question turns out to be the scupper drain hose. And it was laid between the fuel tank and the bulkhead lying on the fiberglass stringer below. With a sort of sharp bend. I have to assume this is how it was installed at the factory with the notch cut for it and all.
While taking pictures I noticed a wet spot under the hose.
Sure enough it has a small hole on the underside were it's been rubbing.
(I taped it up for now. It will be replaced as part of the project)
Unless you were really looking for it, you'd probably not find this hose had failed. In fact one time on a winter inspection trip I found about 1 1/2" of clear water in the pan below the engine. I couldn't fathom how it got there. No obvious places looked wet. Now I know.
Since my boat is only hull #95 there are other things that are different from later boats. (for example it DOES NOT have a seperate filler for the aft water tank) So I hope in later builds they rerouted this hose.
Beware, a good downpour could leave you with significant water in the bildge.
