We're getting there but electric hasn't quite matched an engine for some applications. MOST systems out there have limited range and power, but not all. I think they are excellent for day sailors that only go out in reasonable conditions. Sometimes you really need that extra torque to bash through waves. I don't know how far one would have to go between anchorages in the ICW and if that would add extra time to the trip for recharging.
@dlochner would you be able to answer this question?
Sorry for the late response, I was out of town and didn't bring my laptop.
When range and boat speed of an electric boat are plotted the result is a hockey stick graph, at low speeds the relationship is pretty flat then it curves sharply upward. It's been a couple of years since I used my electric outboard, so I can't remember the exact numbers, however, it was pretty dramatic. At 1 or 2 knots the range was around 15-20 (very slow) miles and at full speed (about 4-5 knots) the range was pretty short around 4-5 miles. Obviously, the outboards battery is much smaller than one used to power a larger sailboat, the relationship, power consumption increases exponentially with boat speed, is the same.
The distance between suitable and comfortable anchorages on the ICW varies widely depending on location. In some areas, like the Wacamaw River in SC there are anchorages every couple of miles. In other areas it could be 20 or 30 miles. The other factors to consider are tide currents and wind driven currents.
Battery capacity and charging ability will affect range. Figure average daily solar production to be 3 times the nominal capacity of the panels, especially in the late fall to early spring months. Between frequent bouts of cloudy and stormy weather and a low sun angle there will be more days below 3 times nominal than above. Summer months will see better production with a few days pushing 4 times nominal capacity, most days will be closer to 3 times than 4 times.
Developing some real time consumption and solar production data will be important to aid in the course planning. This is no different from obtain fuel burn rate for a diesel. A big difference is the energy in a gallon of diesel is pretty consistent, the amount of solar energy generated in a day is highly variable and unpredictable.
A small outboard can be used to move a 33' sailboat, however it will be slow going. If I were to do something like this, I'd have remote engine controls and would lock the motor in straight using the tiller and rudder to steer the boat. Some maneuvers will be exceptionally challenging, such as backing into a slip, negotiating a tight fairway, or fighting wind and current.
