Hi All,
I have an issue that I hope I can get some advise for. I have a 1993 Hunter H 19 (19-2) and the bottom trailing edge of the keel is splitting, that is not what I am asking about (unless you feel like doing some glass work).
I am in need of some advice and directions on exactly how to remove the keel from the trunk. I think the bolts are likely located where the compression post comes down to the sole, but there is a fiberglass / plastic covering over it and wanted to know how it is attached before tearing at it with a screwdriver or something like it only to find out that there is some "trick" to remove it.. and having it crack.
I need to remove the keel, do the fiberglass repairs and probably replace any bushings and bolts if they are rusted so any guidance in this area would be helpful.
Thanks
Thanks
