gimballing feature on gas stove
  • Thread starter viduta, trish dora jane
  • Start date
V
We just purchased a 1988 Catalina 27. PO is out of country for a bit so can't ask him. Stove top is Hillerange, Princess model, by Seaward. How do you unlock it for gimballing feature? I called company and they could not help me w/o model #, which I can not locate. Am assuming is prob underneath, which of course, I can't see, because I can not figure out how to unlock it. She mentioned little deadbolt like feature on front but I did not see anything like that anywhere on it. Then she said it wasn't a design which is intended to gimball. I think she may be incorrect as it is installed with the swinging type apparatus/feature. What am I not seeing?
Catalina 320 Dana Point
Seems like most have that latch
at the back of the stove, in the center about an inch down from the top. Spring loaded in a gateway it frees the two pins at the rear corners, don't expect much tho', you can level it for list but it's not gonna keep the soup from spilling in a seaway.
Sep 6, 2007
324
Catalina 320 Gulfport, Fl
Check both sides of the stove near the bottom
If it can be swung free, there will be a small rod on one side or the other preventing the stove from swinging. Follow the rod to the stove and you should find the release which will either be a mechanical lock or a spring loaded lock.
Good Luck.
