Gauerhauer Rigid Boom Vang
Jul 14, 2015
840
Catalina 30 Stillhouse Hollow Marina
When I got my boat rigid vang was already there. I cannot find anywhere any instructions for spring tension. Is there any adjustment?
Nov 8, 2010
11,386
Typically not. The force is normally sized and based on the size of the unit and the boats it is designed for. It is a spring or a gas piston? The gas pistons fail over time and need replacing.
Dec 2, 1999
15,184
The spring tension was determined by the size of the unit that was originally purchased (based on the size of the vessel)
Jul 14, 2015
840
I assume if I put the topping lift back on and raise the tail end of the boom the last 4 feet of raising the main will be a lot easier
Nov 8, 2010
11,386
Yes. If your vang is shot and your boom droops, you will get to the point near the end of the hoist where you are pulling the mainsail up by its leech and not the luff. Thats HARD.
Jul 14, 2015
840
Thanks jack
mortyd
Dec 11, 2004
952
Catalina 30 easy living
have you considered the possilblity of calling garhauer? they are among the most helpful of folk out there.
Catalina 320 Dana Point
The rigid vang on my boat didn't hold the boom above the dodger so I removed and took it in to Garhauer, they said" Looks like it's missing a spring" They pulled it apart and it had 3 springs and originally shipped with 4, they put a 4th one in. No charge, nice people.
Exact same thing happened to my friend in Chicago. He described what he found to them over the phone, they sent him the spring. My friend is not the handiest of folks, but is certainly willing. If he can do it...:)
I started to take it apart, but had visions of little parts or bearings flying everywhere, turned out it was incredibly simple, only took 15 minutes and most of that was walking across the shop.
