Fuel line maintenance
NYSail
Jan 6, 2006
3,187
Beneteau 423 Mt. Sinai, NY
I bought the racor 500 to take care of any water in the tank.... also I hate old fuel. So typically the tank is a bit under a quarter when I put her to bed for the winter.
JamesG161
Feb 14, 2014
8,105
Hunter 430 Waveland, MS
you really do not have to fear condensation as a tank contaminant.
True!!!:thumbup:
I don't fear, at my Latitudes. I didn't want to get a "condensation controversy".
But for Latitude 32 and Gulf waters...
10 % diesel level in 50 gallon tank. One tablespoon full of water (engineering calculations), would condense for the whole winter season, which BTW will dissolve in the diesel.:waycool:
Jim...
Aug 9, 2011
35
Pearson 30 Chicago
If you store your boat on the hard- every spring I stick a copper tube at the bottom of the tank ( thru the fill port- bend it do it goes deep)and use a hand pump to suck out a sample-clear glass gin or whisky bottles work fine. You may want to do several extractions. You're looking for water and dirt in the bottle. For gasoline tanks, you can decant the fuel thru a coffee filter in a funnel back into the tank. Pitch the last inch or so of grunge in the bottle, and marvel at the crud your fuel filter doesn't have to eat. After sitting for several months in the yard, any crud that's going to settle to the bottom has done so. Yearly extractions will tell you whether you're keeping up. Other posts are accurate- keep extra filters on hand.
