Thought mine was a project
but good luck with your project. I just put a 27' Hunter back in the water after a couple of years of fiddling with it. I still have alot of work to do but she is useable now. I had to rebuild the engine replace a lot of wood in the cabin and I still need to re paint or gel areas of the topside. I agree with the posts that say do NOT make any major modifications. I learned that the hard way froma 16' go fast project. Sometimes the silliest little change messes the boat's integrity in serious ways. (I split the hull and sunk that boat) So stick with the original layout clean her up replace all your wiring and lines and you will have a blast and spent more money than you thought you would. But when you hit the open water and raise the sails it's a rush.
