Patrick, with what ever help you can get from your
kids start taking a inventory of the things that you can see needing done. Before you remove the bulkheads get the sticks off her. Coil the standing rigging and label each piece with a durable tag and permanent ink. When the bulkheards come out install a temporary brace from the low point in the hull to the cabin top at each station. As you start removing pieces you will be removing some of the stiffeners. Be watchful about keeping her shape. Measure her in several places for beam and height and record those numbers, use a tic stick to take shapes before you remove pieces where you can. There is a weather proofing putty used by electricians that is good for temporarily plugging above the waterline holes. The leaking through hulls can be helped just by tightening the nut on the inside. If you could get her on the hard for the long term you would be better able to work.
