Fixed Window Replacement
Mar 27, 2024
36
Hunter 39 Wickford
I want to replace the frameless fixed windows on my Hunter 39. Does anyone know where to source the material? I'm assuming it is acrylic but if anyone knows exactly please let me know. Also if anyone knows the percent of tint. I can cut the raw material so that is not a problem. I'm having a problem finding where to buy it so any advice will be greatly appreciated.
Sep 24, 2018
4,099
Catalina 30 MKIII Chicago
Any plastic supply hour or fabricator can sell you the material. TAP Plastics is often recommended. Have you cut this material before? It chips at the edge very easily if not done correctly.
There's a lot of debate between acrylic and polycarbonate. Acrylic wins these debates more often.
Sep 24, 2018
4,099
If you are familiar with routers, a profile bit will give you flawless edges
+/- 0.001" at high speed and light pressure.
If you are serious about doing this, PM me.
It absolutely will. I've gotten perfect cuts going slowly with a fine toothed table saw blade as well. There's more advanced techniques that involve heat to get a crystal clear edge. I do not recall the equipment needed for it however.
Next time I need a good clean edge, I'd probably cut with whatever saw I please and finish it with a router. It would take a few test strips to get everything setup correctly.
If the OP tapes the old window to new material to use as a template on a table saw, what complications can be expected?
RussC
Sep 11, 2015
1,689
Merit 22- Oregon lakes
I got my plexiglass here Amazon.com and am very happy with it. tint is just right for privacy wile not blocking vision and it works easily. cut with bandsaw and routed the edge. drilling screw holes was no issue either. different sizes available to fit your needs.
dLj
Mar 23, 2017
4,827
I usually buy from Mcmaster-Carr. They tend to be a bit pricey, but they specify what you are getting. The Amazon link above does not give me the information that I would like to have on what the actual product is. If you wish to go with acrylic, then you want cast acrylic. We can get into the debate of acrylic vs polycarbonate if you'd like (guessing not)...
Here's a link to Mcmaster that is cast acrylic - also has the colors and tints...
dj
Mar 26, 2011
3,858
Corsair F-24 MK I Deale, MD
Don't assume that windows were cut to the perfectly correct size the first time. Look closely. When I replaced mine it was clear one was not correctly fitted at the factory, perhaps contributing to leaks 30 years later. There wasn't enough room for sealant movement on one side. I can't complain, but I did trim the window a tiny bit differently when replacing it.
Jan 4, 2006
7,458
I don't know what would happen using the original piece as a template on a table saw. I would live in holy fear of the acrylic dust getting between the two pieces and raising hell. I just mark out the new acrylic with a felt pen and then plough it through the table saw with the carbide blade. It's only a crude cut with edge chips and other flaws. Cut it 1/4"+ bigger than the original acrylic. Do the +/- touchy feely work with the profile router bit.
When using the profile router bit, I always hold the original and new piece of acrylic together with double sided tape.
dLj
Mar 23, 2017
4,827
I use my jig saw with T101A blades. They cut acrylic and polycarbonate like butter and leave a really nice clean edge. You do have to be careful cutting curves if the radius is small.
dj
  • Helpful
Likes: RussC
Sep 24, 2018
4,099
Oh yeah, try to avoid screw holes if possible. Very easy to overtighten and create cracks down the line. BoatWorksToday has a video on using VHB tape to hold it in place while the sealant cures
This is exactly what I meant
And if for some reason it is necessary to use screws or through bolts, drill oversized holes. Acrylic and steel have different rates of thermal expansion. If the hole is snug the acrylic will crack when the screw expands.
RussC
Sep 11, 2015
1,689
don't ya just hate it when that happens. :beer:
Aug 11, 2011
1,013
O'day 30 313 Georgetown MD
I believe thats what I got. What ever is the darkest. During the day you cannot see in unless you have a bright light on inside the cabin. Seeing out is like looking through sunglasses. To help with privacy I made and added curtains.
JBP-PA
Apr 29, 2022
726
Jeanneau Tonic 23 Erie, PA
I got mine from TAP plastics, they were the only source I found that had what I wanted in the right sizes. I could not find affordable UV resistant polycarbonate. I ordered 3 rectangular blanks of acrylic a bit oversized. I got dark smoke, but regret it. It blocks the heat and affords amazing privacy (you can't see in, even at night, unless you are really close), but is very dark in the boat now. I'd go for light smoke if I did it again.
I rough cut the blanks with a jig saw, used a flush cut router and the old window as a template to get the final dimensions. Cleaned up the router marks with sand paper, used a round over router for a nice edge, and finished with finer grades of sand paper and polish.
Mar 27, 2024
36
Hunter 39 Wickford
Thank for the link. I had found them. I was nervous placing an order with them for the reason you stated. I didn't know the tint level to specify. I have lead on a local plastics place. I'm going to try to get over there this week and see if they can help me. I will report if it is successful.
My port lights aren't 90 degree cuts. Couldn't possibly be that easy :D. They have a very sharp bevel on them. If it were wood I can cut the bevel on my table saw. I am hoping a fine tooth blade will work with this material. If anyone has any advice for that I'm all ears.
dLj
Mar 23, 2017
4,827
I would rough cut with my jig saw then finish with a sander. But I've used my jig saw for decades in boat projects so have a good handle on how it works.
Some folks have luck with routers, but I haven't had success that way.
You can certainly try a table saw. I'd get a fine tooth blade made for the job. It's amazing how much better cuts you get with the correct blades...
dj
Likes: JBP-PA
JBP-PA
Apr 29, 2022
726
TAP plastics sells sample pieces cheap.
I think it would be easier to do the bevel with a router (many libraries will lend you a router or other tools.) Mine were a bevel, but I like the round over better.
