Exactly right! All preference really.Split rings are no more prone to failure than stainless wire or cotter pins. There should be no load whatsoever on these things as they simply secure the fixture.
No more so than cotter pins or tails of twisted wire. If snagging is an issue, then butyl sail tape is a great way of covering them up. I would argue that split rings, properly applied, are actually less prone to snagging than either of the other two suggestions.It's not a questing of loading. The problem with split rings is that they are more susceptible to snagging on things and getting twisted.
Google "Rigging Tape" $10-20 a roll.What is "butyl sail tape"? I have some butyl tape I got from MaineSail, but it is a sticky grey stuff that I use for bedding. If there is some kind of specialty tape that is good to wrap around the pins in the turnbuckles, I may buy some. For example, on the turnbuckles that secure the lifelines.
Or the even cheaper, white electrical tape.Google "Rigging Tape" $10-20 a roll.
I added to my wishlist on AmazonEssentially the same stuff. Essentially.
Scar-pins are handy but fail easily. Many of them will break where the pin is attached to the velcro. This kind of deal is really intended for people that adjust their shroud tension every day. Most people that do that now secure their rigging another way, most commonly by securing the turnbuckle bodies of the uppers and lower shrouds together with dyneema, or a small batten. If the bodies cannot turn the tension will not change.This is what I use on another boat. It's a pin riveted into velcro, insert the pin and wrap it. Note that these come in different pin sizes.
http://www.apsltd.com/sp2-scar-pin-1-16-quot-pin-8pk-gray.html
Exactly. It's easy on easy off. And yes, the velcro will crack, they need to be replaced every couple of years.... This kind of deal is really intended for people that adjust their shroud tension every day....
