Finally got the boat wet
P100D
Jul 24, 2016
129
Hunter 23 Nashville TN Percy Priest lake
Split rings are no more prone to failure than stainless wire or cotter pins. There should be no load whatsoever on these things as they simply secure the fixture.
Exactly right! All preference really.
Likes: Ron20324
Sep 19, 2016
172
Caliber 33 Sebastian, FL
It's not a questing of loading. The problem with split rings is that they are more susceptible to snagging on things and getting twisted.
Likes: P100D
Aug 1, 2011
3,972
No more so than cotter pins or tails of twisted wire. If snagging is an issue, then butyl sail tape is a great way of covering them up. I would argue that split rings, properly applied, are actually less prone to snagging than either of the other two suggestions.
Apr 27, 2010
1,279
Hunter 23 Lake Wallenpaupack
What is "butyl sail tape"? I have some butyl tape I got from MaineSail, but it is a sticky grey stuff that I use for bedding. If there is some kind of specialty tape that is good to wrap around the pins in the turnbuckles, I may buy some. For example, on the turnbuckles that secure the lifelines.
Likes: P100D
P100D
Jul 24, 2016
129
Google "Rigging Tape" $10-20 a roll.
Aug 1, 2011
3,972
White butyl tape is not sticky like the good stuff and is usually available from the electrical dept at Home Depot or Lowe’s.
Nov 8, 2010
11,386
This is what I use on another boat. It's a pin riveted into velcro, insert the pin and wrap it. Note that these come in different pin sizes.
http://www.apsltd.com/sp2-scar-pin-1-16-quot-pin-8pk-gray.html
Scar-pins are handy but fail easily. Many of them will break where the pin is attached to the velcro. This kind of deal is really intended for people that adjust their shroud tension every day. Most people that do that now secure their rigging another way, most commonly by securing the turnbuckle bodies of the uppers and lower shrouds together with dyneema, or a small batten. If the bodies cannot turn the tension will not change.
Jun 1, 2018
20
Hunter 23 Brookeville Lake, IN
So it sounds like the best route to take here is cotter pins with electrical tape? I noticed there were a lot of boats that had electrical tape on their turnbuckles at the marina this weekend.
Side note I spent the weekend on the boat doing some random projects but got to sail a friend's O'Day 272 which was super nice. Noticed I needed a lot a practice and got caught in the irons a few times while trying to tack. It was a great learning experience.
gdudik
Oct 25, 2017
87
Catalina 22 Vancouver, WA
We used to always use electrical tape on the FJ’s when I was in college. Always got dried out/cracked/flaky after awhile. That’s why I prefer the rescue tape.
Apr 27, 2010
1,279
If that rescue tape is the non-sticky, stretchy stuff that sort of sticks to itself, you can also buy something like it (or identical to it) at the big box stores. HD has it in the electrical department.
Also, if you like them, use turnbuckle boots - they cover the whole turnbuckle so if you have bent over cotter pins the pin's sharp tips are inside the tube.
Dfed
Jul 19, 2016
25
Hunter 23.5 Augusta
On the scar-pins
... This kind of deal is really intended for people that adjust their shroud tension every day....
Exactly. It's easy on easy off. And yes, the velcro will crack, they need to be replaced every couple of years.
