My new Standard Horizon RAM4 Mic has 2 Ferrite Cores included in the box. They need to be fastened to the cable on both ends of the cable as close to the screw connectors as possible. The instructions say to wrap each with electrical tape to keep them from falling off, as vibration may loosen them. Given where they are finally located , how would you know?
So would you heat shrink them rather than use tape? Tape just seems to dry out and loosen in the heat.
Thank you for the input.
