Dyneema for furler line
Mar 26, 2011
3,839
Corsair F-24 MK I Deale, MD
Warpspeed is kind of stiff as I recall, but it has been a while.
For certain, strip the cover for the first ~ 11 feet (about 4 feet short of the jammer when the sail is deployed; it will become 2 feet once the cover is gone. Look up the instruction. The end of the cover is buried inside the core, like a splice. Very easy, very neat. Don't forget the lock stitches, and lock the cover to the core with a knot or pin before you start.
The cover is always on just one side. What I was suggesting is that the original genoa may have had the cover on the opposite side. Possibly.
Sep 24, 2018
3,987
Catalina 30 MKIII Chicago
Kind of stiff is a good description. It's a bit stiffer than Sta-set but if you try to squeeze it between your fingers, it wont really compress and deform.
"it will become 2 feet once the cover is gone." - Are you referring to the cover on the line or genoa?
Sep 24, 2018
3,987
I just confirmed that the line is 1/4".
I just realized the furler is slanted backwards but the pulpit rails slant forward. Is there an off the shelf solution for mounting a fairlead at the correct angle?
