Whoops hit the wrong button.There will be 2 drafts one with a wing keel and the other a fin keel. I have a 380 wing keel at 1.6 meters, the fin is 2.14 metres. I can only suspect you have a fin keel. Check the spec's on this site.Regards
Eric,As of hull 847 the C320 shares a wing keel design with the C310. It is a shallower keel with bigger wings. Check the C320 web site for pictures that present a side by side comparison.JeffC
JeffC is right. Hull #846 and older have a 4'10" draft, hull #847 and newer have a 4'3" draft. Some Catalina brochures are incorrect and cause confusion. The fin keel draft is 6'3".
I recently bought a 320 and the previous owner told me he discovered the same difference between actual and advertized draft and that Catalina replaced his keel.
