Draft 320
E
Eric Kramer
I have purchased a 1996 320. The draft on specs says 4' 3". It measures 4' 10". Did the 320 wing change drafts at some year?
W
Wayne Elphinstone
Woops
Whoops hit the wrong button. There will be 2 drafts one with a wing keel and the other a fin keel. I have a 380 wing keel at 1.6 meters, the fin is 2.14 metres. I can only suspect you have a fin keel. Check the spec's on this site. Regards
Jun 3, 2004
2
- - Waukegan, IL
Wing changes
Eric, As of hull 847 the C320 shares a wing keel design with the C310. It is a shallower keel with bigger wings. Check the C320 web site for pictures that present a side by side comparison. JeffC
1,077
Several Catalinas C25/C320 USA
C320 Draft
JeffC is right. Hull #846 and older have a 4'10" draft, hull #847 and newer have a 4'3" draft. Some Catalina brochures are incorrect and cause confusion. The fin keel draft is 6'3".
Apr 13, 2005
1
- - estero
320 draft
I recently bought a 320 and the previous owner told me he discovered the same difference between actual and advertized draft and that Catalina replaced his keel.
