Docking and stopping with a spring line
Jan 7, 2011
6,018
Oday 322 East Chicago, IN
I use a spring line and it has revolutionized my confidence getting in and out of my slip…
I am on the Breat Lakes, so no tidal current to worry about. But my slip faces East/West and my finger pier is on the North side. I chose this slip because a South wind pushes me into the finger pier. And since I am on the South end of Lake Michigan, South wind days are best sailing (smaller seas).
But I really want to sail regardless of which way the winds are blowing, so I came up with spring line docking setup that holds Tally Ho up against the pier before I shove off, and also gives me a fighting chance of docking even in a strong north wind.
I have a line cleated to the end cleat on the pier, and it has a loop in it, and the loop has a length of garden hose over it. The length is set by putting the boat in the slip, and putting the loop over my cabin-top winch, and then clearing the end of the line at that length. The loop is kept on a Sheppard hook at the very end of the finger pier and it hangs there when I leave the slip.
When getting ready to shove off, I slip the loop over the cabintop winch, start the engine, and put the boat in FWD. Adjusting the throttle and the rudder angle allows me to keep the boat straight in the slip while I then cast off all of the lines. When I am ready to shove off, I put the boat in REV and as soon as the loop is loose, I re-secure it on the Shepard’s hook as I back out. The garden hose stiffens the loop so I can reach pretty far with it.
When I comeback, I have to get the loop line…that is critical. But if I do get it, then docking is super easy. I keep a boat hook very close at hand when I come in with a North wind in case I get blown off the finger pier. I can still get the loop line and put it on the cabintop winch.
To Dave’s question, if I had to come in hot because of a north wind, as soon as I drop the loop over the winch, I hit REV to slow the boat down, and then, I can put it back in FWD and gently move the boat forward to tighten the loop line. Once tight, use the throttle and rudder angle to hold the boat in the slip. Tie up the bow to keep the bow from blowing over and that is about it. Tie up the stern and then I can put the boat in Neutral and shut down the engine.
i single-hand, so figuring out how to hold the boat in the slip while getting lines off was critical (or I would only sail on a south wind day). And getting back into the slip in a cross wind makes the whole experience less daunting. Now, I have messed up a few over the years…most entailed missing the loop line when coming in with a 25knot cross wind. :yikes:
But I no longer worry about what way the wind is blowing as a prerequisite for going out for a sail.
JBP-PA
Apr 29, 2022
838
Jeanneau Tonic 23 Erie, PA
A person at our club has an entirely different approach. He routinely crashes into the dock. Now, whenever people see him coming in, a dozen people pop up and race to his dock to catch him.
Not recommended.
Sep 24, 2018
4,822
Catalina 30 MKIII Chicago
With my O'Day, I would leave the line on the dock and put it over my main winch. The boat would do the same thing as it does now - reaches the end of the line and then bounces back which makes for easy bow handling. One thing that dawned on me just now is the number of fingers that were pinched or almost pinched between the line and the winch. We have yet to have that happen with the spring line technique, mainly due to two things - having the line attached to the boat saves time vs having it on the dock and having a very large loop. Our fingers are around a foot away from the cleat.
...not to jump off the boat? At your home dock I leave docklines attached to the dock. pick it up off the dock or piling with a pole from your bow, that way if anything goes awry, at least your still with the vessel.
3strand has good stretch.
If the boat starts to go sideways after the spring line is attached, is it easier to find a boat hook and try to grab the dock or is it easier to reach from the dock and grab the boat by hand?
Not recommended.
A week or two after I got my first slip I came in hot, the pulpit slammed into the dock box, I heard a cracking sound of fiberglass, grabbed a hold of the dock and looked up, paused, and realized, I was at someone else's slip!
One technique that works if you have pilings is to form a V with lines running from a piling to the front of the dock and from midship dock cleat to the forward piling on the opposite side... or something along those lines. You'll end up with a V or an X. It acts to absorb shock and allows you to leave the boat in gear without drifting to the side much. It was great but unfortunately, my slip doesn't have pilings or cleats in the correct places
Likes: JBP-PA
You seem to be missing the point of a midships spring line. You do need to practice using it and your engine. Sideways ONLY occurs if your engine is off or in neutral. Once docked with the boat snug to the dock in gear, you tie the breast lines, and only then turn the engine off. NO sideways happens.
Apex
Jun 19, 2013
1,229
C&C 30 Elk Rapids
@Project_Mayhem : once a spring is on, powering forward at idle will pin the boat. Unfortunately my spring is at the bow, so it requires a spring AND stern to prevent the boat pivoting out. a mid-ship spring is much nicer solution.
  • Helpful
1,120
Beneteau 393 Muskegon
I've found the attachment point on the boat and the position of the dock cleat make a difference. If the line runs from a cockpit winch aft to a deck cleat then the boat snugs up very nicely, whereas if the attachment point is nearer to midship, the bow may dive in toward the dock and the stern swings out. As Stu says, this is easily corrected by turning the boat away so that prop wash brings the stern back in. No need to grab boat hooks, jump off, etc.
I never found the sweet spot on my boat to mitigate this and there isn't sufficient length in our slip to lead the line aft of the winch, so we just prepare for this and mainly avoid coming in so hot that the spring line has to do all the work. When things go well, we nearly stop at the point where it tensions, then idle forward to hold the boat on the dock.
Catalina 34 Casco Bay
I have a device that is dropped over the lifeline at the midship cleat. It slides on either side and down to the deck. There is a hinged arm that has a p-cord stopper that keeps the arm level. The arm has a smaller arm that hold a dock line with a loop. The line is cleated off. The loop just touched the dock. Motoring in, the loop fetches up on a cleat and immediately springs the boat in...The device is made out of 1x3 pine and the are pivot point is a simple brass hinge..
capta
Jun 4, 2009
5,123
Wow thank you for all of the responses. I will write a more in depth reply when I have time. For now, I will say that leaving the spring line on the dock takes more time than tossing it over the first dock cleat. This allows more time to correct mishaps and I can toss it from the cockpit if I'm flying solo.
Even at slow speeds, it takes a lot to stop a 10,000 lbs boat. There's a balance between slow and so slow that I lose control. I usually coast in and momentarily idle in reverse or forward as needed. At the last second, I turn to starboard so the stern is close enough to the dock to easily toss the spring line on the cleat. My technique allows me or a crew member to casually walk forward on the dock to grab the bow. Yes, the boat is technically in motion but it is tethered and the helmsman has a good amount of control if needed
My Pearson was 77,000 pounds and my 7/8" Sampson goldlon (3 strand nylon) would stop her just fine at any speed I ever docked her at. Perhaps you could move up a couple of line sizes and feel secure that your spring will do its job?
IIRC, Project mayhem has a Catalina 30. For my Catalina 34, our 1/2" midships spring line has worked for 28 years. Once you get bigger, even 5/8" gets beyond the size of the cleats to hold the line properly. 1/2" is more than adequate.
Likes: capta
capta
Jun 4, 2009
5,123
I did not mean he should go up to 7/8, only that he find a size line he could depend on for his boat.
Likes: Stu Jackson
Sep 24, 2018
4,822
It's the hardware on the boat I'm concerned about. The midship cleat is on a T track that is fastened to the deck with 1/4" bolts.
I feel confident in 3/8" line doing the job like it has many times in the past. I believe my line is 1/2" or 5/8". I will definitely try some nylon three strand as someone suggested for some more stretch
Likes: capta
capta
Jun 4, 2009
5,123
While you are at it, pick up enough 3 strand nylon to make a snub line for your anchor, if you are using all chain.
Nov 8, 2007
1,621
Sideways is easy when the engine is engaged forward and the springline is taut.
Steering the bow into the dock will move the boat sideways away from the dock.
Steering the bow away from the dock will move the boat sideways toward the dock.
These movements are gentle, and easy to control.
Oct 6, 2007
1,185
Hunter H30 1982 Chicago IL
I did not respond earlier because I don’t think the OP’s Catalina has the perforated aluminum toe rail central to my particular stopping spring line set up, but after reading the comments, I believe parts of my system are still relevant to the general discussion and may be useful to others. As usual, my post is a bit long because I can’t help being very detailed.
I have port side docking and use a stopping spring line that is a single large loop with both ends attached to the aluminum toe rail with heavy duty stainless steel bolt lock carabiners positioned a little aft of mid-ship. That and the bow and stern lines stay on the boat. Separate dock spring lines stay on the dock. Adding a mid-ship deck cleat is not appealing because my side decks are narrow. There is no genoa track. I started with a folding cleat bolted to the toe rail, but I thought it too light weight for stopping 10k lbs of boat and it attached with just a single bolt, which I found disconcerting. I have 100% confidence in the carabiners. The toe rail wall is quite thick, about 3/16”, and using two carabiners in separate holes distributes the load. The line is 1/2” double braid dock line, but it’s getting old and I’ll probably switch to triple braid soon for added stretch.
I approach the dock slowly, almost stopping a bit short, put it in neutral gear and drop the stopping spring line on the first dock cleat. Then I put it in forward gear, idle speed or slightly more depending on the wind, and turn the wheel hard to starboard as the stopping spring line goes taught. This drives the stern to the dock (port) counter balancing the tendency of the stopping spring line to swing the bow into the dock. When I get it right, which is most of the time, the boat just slowly snugs up parallel to the dock. A little too fast and the bow swings into the dock. There are three fleece covered fenders fixed to the dock mid-ship and a large fender forward on the dock to protect the forward port side hull. When the boat stops snug to the fenders, I lock the wheel, leave the engine in gear and calmly step off to secure the bow and stern lines knowing that the boat is pinned to the dock and will stay there until it runs out of fuel.
When the boat is secured, I turn off the engine and straighten the wheel, then switch out the stopping spring line for the two dock spring lines and hang the coiled stopping spring line on the life line. The reason for the switch is that I don‘t want the carabiners rattling and wearing on the aluminum toe rail 24/7. If the stopping spring line could be one or two positions further aft on the toe rail, there might be a bit less bow swing to the dock, but I need those toe rail positions for the snatch blocks I use when reefing the genoa, so there’s a small compromise.
Overall, this system works very well for me. I solo sail most of the time, but the system is simple enough that I’m comfortable allowing inexperienced guests to drop the stopping spring line loop on the cleat. As long as the line is outside of the life lines, it’s pretty idiot proof. What I don’t like is people on the dock grabbing and pulling lines to help. That messes things up quickly. I just politely say “No thanks, I’ve got this”.
