I use a spring line and it has revolutionized my confidence getting in and out of my slip…
I am on the Breat Lakes, so no tidal current to worry about. But my slip faces East/West and my finger pier is on the North side. I chose this slip because a South wind pushes me into the finger pier. And since I am on the South end of Lake Michigan, South wind days are best sailing (smaller seas).
But I really want to sail regardless of which way the winds are blowing, so I came up with spring line docking setup that holds Tally Ho up against the pier before I shove off, and also gives me a fighting chance of docking even in a strong north wind.
I have a line cleated to the end cleat on the pier, and it has a loop in it, and the loop has a length of garden hose over it. The length is set by putting the boat in the slip, and putting the loop over my cabin-top winch, and then clearing the end of the line at that length. The loop is kept on a Sheppard hook at the very end of the finger pier and it hangs there when I leave the slip.
When getting ready to shove off, I slip the loop over the cabintop winch, start the engine, and put the boat in FWD. Adjusting the throttle and the rudder angle allows me to keep the boat straight in the slip while I then cast off all of the lines. When I am ready to shove off, I put the boat in REV and as soon as the loop is loose, I re-secure it on the Shepard’s hook as I back out. The garden hose stiffens the loop so I can reach pretty far with it.
When I comeback, I have to get the loop line…that is critical. But if I do get it, then docking is super easy. I keep a boat hook very close at hand when I come in with a North wind in case I get blown off the finger pier. I can still get the loop line and put it on the cabintop winch.
To Dave’s question, if I had to come in hot because of a north wind, as soon as I drop the loop over the winch, I hit REV to slow the boat down, and then, I can put it back in FWD and gently move the boat forward to tighten the loop line. Once tight, use the throttle and rudder angle to hold the boat in the slip. Tie up the bow to keep the bow from blowing over and that is about it. Tie up the stern and then I can put the boat in Neutral and shut down the engine.
i single-hand, so figuring out how to hold the boat in the slip while getting lines off was critical (or I would only sail on a south wind day). And getting back into the slip in a cross wind makes the whole experience less daunting. Now, I have messed up a few over the years…most entailed missing the loop line when coming in with a 25knot cross wind.
But I no longer worry about what way the wind is blowing as a prerequisite for going out for a sail.
