Since I rarely had a slip, no lines were neatly set up on the dock. Once I had a spring from the boat to the dock and her stopped, I would leave the boat in gear with the helm hard over which would leave the boat pinned parallel, close alongside. Then, I could casually step ashore (or my crew could) and get the stern line on first and the bow after that, and step back aboard, pull her out of gear and secure the lines as needed. It worked in a beam off the dock wind and/or current, I just had to increase the throttle to compensate.
It was very important to me that no one, under any circumstances, jumped even one inch. If I couldn't put her right alongside, so that I or my crew could casually STEP ashore, I'd go around again. It was my job to put her alongside properly, not ask anyone to save my lousy docking by taking any chances jumping.
As for marriage savers, that rule, and taking the time to discuss the docking before we even began the maneuver, worked to avoid injuries and/or bitter words in the heat of the moment. Very rarely were words necessary. A single hand signal was sufficient, in most cases, to get the anchor down where I wanted it, or a boat pole pointing at the mooring ball by the person forward, if picking up a mooring.
If single handing onto a mooring, I'd have a line, run outside everything, from the bow to a position where I could easily get the ball right alongside me (center or aft cockpit) and pick up the ball, and thread the line through the eye. Then I could leave the helm and pull the bow to the mooring.
I'm not a fan of the old, "Don't enter a slip any faster than you want to hit the dock." philosophy. As I see it, that's when the wind and/or current may overpower your intentions, increasing your chances of hitting the dock, or a boat alongside. Like anything else on a boat, the more you do it, the better you get at it. If docking (or departing) is something you dread, then take a day now and then, to just dock and depart, over and over again, all day, like pilots do touch and go landings. Forget about that day for going out on the water.
