It is a law here in WiI feel like this may be a stupid question that will get me burned! But, my Venture 21 came on a trailer with no straps and there are no tie down eyes on the transom or otherwise available for tying down. Do you tie down if you're going to go on a long trailer journey? Or is gravity and sufficient?
Yes, it has a bow eye and of course I use that to winch to the up forward on the trailer. I don't use any additional straps to move it from my home, 3 miles to my ramp to put in, but I will for trips further than that or on questionable roads.@Chuck_FLA
The venture 21 is either a swing keel or a dagger board. Please advise which one. In addition, please advise whether or not if you have a bow eye or not? One two inch strap is needed to secure the cockpit to the trailer only. Do you have a locking winch with strap and a safety chain? Pictures of bow eye, trailer winch stand and rudder (if left on boat during transport) would help. Then I would tell you how I would transport a venture 21
Former sailboat dealer
DaveSuggest one strap over the cockpit. If new, I would recommend cushioning it going over the edges. Never put a strap over the foredeck; otherwise, the hull would be drawn down at the end of the bunk boards. Put a couple of twists in the strap to prevent any slapping.against the hull.
After going 10-20 miles, pull over and check the following:
1. Check the winch strap for any loosening
2, Ensure the safety chain is secure and not slapping the bow
3. Tie winch handle to winch stand should handle come
loose
4; check tightness of strap
5. Check tire hubs for excessive heat
6, Check lines securing mast to boat
7 Is rudder secured
8. Is motor secured
Every hundred miles, suggest rechecking above
Do you ever see a truck with cargo that is not strapped or chained down? It is sort of ... illegal not to and points on your license if it is spotted.I feel like this may be a stupid question that will get me burned! But, my Venture 21 came on a trailer with no straps and there are no tie down eyes on the transom or otherwise available for tying down. Do you tie down if you're going to go on a long trailer journey? Or is gravity and sufficient?
