- Oct 22, 2014
- 24,788
Tom. That would depend. Perhaps in college that was the best you could be. Now just trying to live up to the memory.I’m all better now.
Ya got lucky!Someone mentioned the situation of going down wind, Guy has been steering the boat but hands the helm over to someone else and goes forward for some reason and an accidental jibe happens at a really bad time..
Well.. that pretty much also describes my case. We were headed down wind wing on wing and got near the marina entrance. No preventer.. I handed the tiller over to my wife, said just keep going in the exact direction as we are going. I went forward to remove the whisker pole. On the way back the boom swung around, caught me and took me over the lifeline. Fortunately the main was loose footed so I was able to hold onto to the boom or I would have been thrown in some mid 50's F water.
If your heading down wind and go forward for some reason.. make sure you know what or who is steering the boat is paying attention. Or.. a preventer. I imagine testing out a preventer might be a little on the stressful side also.
Terry has nailed an important skill.Autohelm is very good, not as quick as the skipper's touch.
I'm (probably) younger, and sometimes sail under jib alone as well downwind... I'm not going to win any races... but with a family on board, especially heading downwind, the mainsail doesn't help enough to justify the hassle/danger sometimes. This was even more true when my old boat had a mainsail I had to pull down/flake/tie/cover with halyards, lines ending at the mast, rather than running back to the cockpit, whereas I now have a roller furling main above a bimini, so I use it more than I used to... plus my kids are teens rather than toddlers, so IN THEORY they should be able to understand "Wait a minute" better when I'm busy with the sails, etc... ha... right... who am I kidding... that hasn't changed a bit.We’ve found gybes to be dangerous and expensive so we’re preventing them by dropping the main if we have to run downwind. Not only is it safer, it is a lot quieter. If it takes us a bit longer we just adjust our schedule.
On occasion heading upwind I will do a “Crazy Ivan”, but only with light winds and extreme boredom. At our advanced age our resolve is to stay aboard and not get hurt.
I peaked too soon.
Todd, one of the reasons for the thread was to help sailors understand the danger and to control it by using a preventer. I understand the statement of "hassle". It seems the that you have addressed it by having a "furling mainsail".the mainsail doesn't help enough to justify the hassle/danger
I like it. Self preservation.I do not trust their ability to walk the tightrope wing on wing without jibing. Since I mostly solo this is not really a choice.
But you have to be careful; this often creates a bigger problem than the one you are trying to prevent. At some point on most boats, its better to get the mainsail gybe. Holding it back will often for sure break something, and the resulting rapid unloading is often much worse than the original gybe would have been. Or it will pin the boat over in a very precarious position.I like it. Self preservation.
On smaller boats the option to control a 200 SqFt sail with shear manly force is one thing. I get it. I agree and have used similar techniques but probably not with as much flare as you describe. I may need to work on my technique.
To be able to do it with 300-500 SqFt is a different ball game.
Having the "preventer rip the toerail off the deck" is more of the way you attached the preventer to the boat and possibly not understanding the forces that were at play.
As I suggested in the first message I use a "Strong point - Bow cleat with backing plate/padeye with backing plate" to attach the preventer line. The preventer is attached to the end of the boom with a strong knot - bowline. The preventer is controlled in the cockpit and can be released as necessary.
Perhaps this is the point in a nutshell. A preventer is not a fixer it is a tool to prevent the boom from swinging out of control across the deck while downwind sailing. If I do accidentally gybe, I release the preventer lead and can control move the boom to the opposite tack. I release the preventer and move it to the new tack position.you have to be careful
All good points Jssailem. I wasn't very clear on a couple things. I guess I'm not so much claiming that dousing the mainsail is a better alternative to using a preventer. In my case it is more like... I haven't felt the need for the preventer, because often when sailing downwind, I'm sailing with only the genoa... unless the wind is super-light, in which case wing on wing isn't quite as scary (especially with calm seas). And yes, of course that's at the expense of the sails/helm not being as balanced without a main. I'm generally just out sailing around headed nowhere in a hurry, so sacrificing a bit of speed on this one tack isn't a problem for me, and your point of "how long will you be on one tack" is a very big factor. If I were in rolling seas for 8 hours straight, trying to get somewhere downwind, I'd be WAY more eager to rig a preventer... If I'm only going to be on a tack for 15 minutes, and I'm in no rush to get somewhere, it is harder to justify the effort. I'd be more likely to just change my course by 10-20 degrees. Good points.Todd, one of the reasons for the thread was to help sailors understand the danger and to control it by using a preventer. I understand the statement of "hassle". It seems the that you have addressed it by having a "furling mainsail".
I find that the mainsail helps in two ways; maintain speed - when wing and wing DDW your boat has about 700squarefeet plus of sail area out capturing the wind as compared to 300 on the jib alone, and the mainsail helps to provide balance to the rig. That can only happen if you can keep the boom from swinging, thus the preventer.
It is also a consideration; how long will you be sailing in this direction? We have some 3-4 hour passages on one tack. Having a safe way to set the sails downwind can improve our sailing experience.
