Do I want to purchase a 275?
Jul 1, 2023
17
Catalina 275 Riverton
Thanks Chris. You are right. It would be prohibitive to replace the mast and spreaders, but might be possible to run a larger jib to either cars, like they they have, or a snatch block off the stanchions. Will talk to sailmakers and riggers at Annapolis boat show next month. These pics will help that conversation. Also useful for me to know actually that it is possible to place the cars and winches where they have them (wasnt sure how strong the deck was there). I'll let you know what I hear.
May 18, 2025
5
Catalina 275 Sport King Harbor Yacht Club
Please do, would love to get a larger jib, even if I can get a 125-135 it would help!
Jul 1, 2023
17
Talked to North Sails and Doyle yesterday. Both said a large Genoa would not work on our boats because the spreader stay chainplates are too far out on our decks (ours are at the toe rail, compared to the boat you pictured where the chain plates are against the cabin). So on our boats it would not be possible to pull the gennie in tight, negating any upwind advantage. However, the Doyle salesman talked to the engineer who designed the original sails for our boats. His suggestion was a headsail with the same foot as ours but a larger roach, more area at the top of the leach, which would give more upwind power (same idea as the squared off mainsails). They can also make it from a lighter composite which will add performance His estimate for cost was about $2750. Northsails has not yet sent a proposal but they had a similar idea. Im probably going to try this. If you are interested I can see whether we can get a price break for 2 (or more if anyone else is interested)
May 18, 2025
5
I’m interested, who is your North rep? I’ve been talking to Parker Mitchell about some ideas to. If we can get some new composite genoas that approach 110 with big roach area it would be a good start.
Jul 1, 2023
17
The local North Sails rep is not reliable (I know a couple guys who bought from him and got bad advice). We talked to Anson Mulder, who is based in Florida but was at the boat show.
Do you know any other 275 owners who may be looking to upgrade?
I think that jib will have battens. That might prevent furling. Maybe they can vertical. Even so I don’t think you’ll store the sail on the forestay. You can get a sun cover for it. Seems like a lot of trouble to me.
I don’t know if a roachy job will get you a PHRF penalty.
Jul 1, 2023
17
Just got the proposal from Northsails. Similar strategy, about $600 more than Doyle ($3350). Im not sure whether this is a private channel, and probably shouldn't be dropping their proposals out in public, how would you feel comfortable with me sending them to you
Jul 1, 2023
17
Andrew, the stock 275 jibs furl with vertical batters. It us a bit of a pain when swapping sails because you need to remove the battens to flake the sail. Both the North and Doyle sails have UV cover strips. Don't know how much value the roach sails will add, but my boats 10 years old, prob time for a new sail anyway
